new blower motor not turning on
Page 1 of 10 12345678910 LastLast
Results 1 to 15 of 147
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new blower motor not turning on in Past Cadillac Vehicle Discussion; hey everyone i have 94 deville with the 4.9 engine.i had a bad blower motor so i installed a new ...
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    39
    196
    hey everyone i have 94 deville with the 4.9 engine.i had a bad blower motor so i installed a new blower motor in it and it does not turn on.i took it out out bypassed the motor to see if it would spin and it did so i know now i know that the motor is not bad so i put it back in.i checked the fuse and it was ok.any suggestions and help would be much appreciated.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: new blower motor not turning on
    Bad blower speed switch, blower resistor problem, no ground, lack of voltage to blower motor.
    Blower motor schematic will be needed.
    Mar 2014
    39
    196
    hmm if i send you schematic will you help me out more?
    @98eldo32v
    Mar 2014
    39
    196
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Thank you Mr. Starks for the speedy image......
    Not too much to this circuit, check maxi fuse, voltage at blower motor from fuse. Check for ground at blower motor.
    Worst case scenario, you need the a/c and heater programmer
    Check fuse to see if it is blown.
    You will need a test 12v test light for further testing.
    From the diagram, the blower motor looks like it has a 3 pin connector.
    Pin "A" is ground, Pin "B" is 12 v "HOT" at all times, Pin "C" is the controller line.
    With the 3 pin connector removed from the blower motor, with the test light you're jumping pin "A" to pin "C". If the test light lights up, this will confirm you have voltage from the fuse at pin "C" and ground at pin "A".
    With that eliminated, you're back tracing pin "B" to the a/c and heater programmer.
    If the blower switch is available separately on the a/c control head, that will be more than likely the suspect.
    Mar 2014
    39
    196
    @98eldo32v do i need to check the relay and resistor going to the blower motor?
    Mar 2014
    39
    196
    how do i jumper them?i got a test light with 2 jumper cables connected it and into the a and c terminals on the connector and a sparks flew...
    Mar 2014
    39
    196
    so i got a wire and connected pin 'a' to pin' c' and sparks flew agian am i doing it right
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Sean you can't just jump pin A to pin C, you need a test lamp to do that.
    If you have sparks, OBVIOUSLY, you have voltage from the fuse line (pin c) to ground (pin a). Double check the fuse to make sure you haven't blown it.
    To connect the test light to the terminals, stick a piece of wire into each terminal. Then connect one end of the test light to one end of the terminals, the opposite end if the test light to the other terminal. The lamp should light up then.
    In reality, you already have voltage if you're getting sparks.
    You're problem is going to be in the control head
    Mar 2014
    39
    196
    @98eldo32v the control head?are you talking about the ac/heater programmer.whats the next step for further testing ? tanks alot your help is much needed
    @98ELDO32V also I did the test light check and the light only light up on one side which was ''A''.does both sides have to light up or only one side
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    The control head is where you actually manually turn on the heater/ a/c and control the fan speed.
    Let me look up how this thing looks
    The light should have lit up with one end of the light attached to pin a, while the other end of the light attached to pin c. That means you have voltage from pin c, and a good ground at pin a.
    The programmer is located under the dash, more so to the passengers side. Black box that appears to have vacuum lines running to it and electrical connections.
    I'll see if I can get a part number on it ......
    According to what I've found you need a 16180786 or a delco 15-72247, which isn't cheap.
    The search continues.............
    Mar 2014
    39
    196
    @98eldo32v or is the control head the climate control panel on the instrument panel?
    @98eldo32v so what should i do next ? test the ac/heater programmer and control head to see if they work
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    The instrument panel has the buttons, the programmer does the "actual" controlling or switching of the blend doors and speeds.
    Rock auto.com lists the programmer and the blower resistor for a 94 Deville with a 4.9 but researching the programmers uusually turns up the programmer as the main issue. You can possibly try a used one, but that one may have an issue with it also.
    Rock auto part number for the programmer through Standard Motor products is PRG10, with the core charge you're looking at 184.79
    That part replaces 16180786,16192686,16210961.
    You might be able to you those numbers as reference to find a possible used replacement if not going the remanufactured route....
    http://www.ebay.com/itm/CADILLAC-DEV...7fccba&vxp=mtr
    I need to research this some more.....
  16. #14
    Mar 2014
    39
    196
    @98eldo32v is it possible to test the ac programmer with a test light so see it works.becuase i can hear it make noises when i push the buttons to turn on the ac so maybe it does still work
  17. #15
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Parts of the programmer still work, obviously not all functions.
    There is probably a way to test the programmer, but we need probably need the factory service manual.
    I'm researching some other things pertaining to this.....hold on
  18. Remove Advertisements
