new blower motor not turning on - Page 9
Page 9 of 10 FirstFirst 12345678910 LastLast
Results 121 to 135 of 147
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new blower motor not turning on in Past Cadillac Vehicle Discussion; Originally Posted by Ranger By checking your high and low pressure readings with an A/C manifold gauge set. Or by ...
  1. #121
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    40
    196
    Re: new blower motor not turning on
    By checking your high and low pressure readings with an A/C manifold gauge set. Or by having it recovered and weighed.
    question if you install a new compressor do you ''have'' to replace the drier and the ac hose with it?
    ....@eldoluv32v pep boys checked my ac system did the leak test with the dye and said that my compressor and ac hose is bad and they also said that they have to replace the drier too because once the open it up they have to replace it is that true??
  2. #122
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    If they are "suggesting" replacing the compressor , the a/c muffler hose , why stop and skimp on the drier? Again with the age of your vehicle, it's time to bite the bullet.
    Normally you can just change the compressor, the drier and orifice tube.
    .If they are suggesting the a/c muffler hose, then it is with good reason you should.
    If in doubt take it to another shop for a second opinion.........
    If it was mine, I'd change everything.
    You don't want problems later. You haven't had the system operational in quite some time.......
    Do some searching online for the parts is possible or get a quote them with the necessary parts and see if they are whacking you over the head...
  3. #123
    69
    82,377
    Quote Originally Posted by sean starks View Post
    "Have to" depends on why the compressor was replaced. If it started throwing debris through out the system, then yes, the drier cannot be flushed.
    No, it does not "have to" be replaced simply because it was opened. It has a desiccant drier in it to absorb any moister that may get in the system, but that's why you pull a vacuum on the system before recharging it, to remove any moisture that was introduce from opening it.
  5. #124
    Mar 2014
    40
    196
    hmm after i took it to pep boys i looked under the hood and there was this green stuff around the ac lines and hoses..what is that?
    Quote Originally Posted by 98eldo32v View Post
    yea they are whacking me over the head the quote they gave me for all the parts was 340 with parts alone.
    looked on ebay got all the parts i need for 130 lol.
  6. #125
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    May I suggest NOT having Pep Boys work in the car?
    The green stuff could have been several things. Was it near the A/C service ports?
  7. #126
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    God I hope it wasn't tire slime and the valve stems...
    Sean, find a real mechanic and get an estimate... You have multiple issues I think. Second opinions are a very good thing.
  8. #127
    Mar 2014
    40
    196
    yes it was near the service ports.. is it that ac leak dye stuff..if so does that mean thats where the ac leak was exposed?
  9. #128
    Mar 2014
    40
    196
    does anyone have know why when i turn the heater on it only blows on the floor and winshield only and not the dash vents?
  10. #129
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    By design, heat will only come from floor and defrost... 2000 was the first year you could make it come from the dash vents.
  11. #130
    69
    82,377
    Based on this question and without going back 8 pages to research I would guess you are talking about a pre-200 like Rod mentioned, but we wouldn't have to guess if you add your year and model to your profile.
  12. #131
    Mar 2014
    40
    196
    94 deville 4.9
    so since im waiting on the ac parts to arrive.. how do i flush the heater core is there a specific procedure to do it?
  13. #132
    69
    82,377
    Disconnect the inlet and outlet heater hoses at the firewall (or follow them back to the T fitting if that's easier). Connect a garden hose to one and flush it out the other, then revers the procedure.
    P.S.
    Mark the hoses so they go back on the same legs of the T fitting.
  14. #133
    Mar 2014
    40
    196
    P.S.
    well havent had time but i ordered a new heater core..how do i take out the heater core
  15. #134
    69
    82,377
    Not sure as I never had to replace one, but I can assure you it will take much more time than flushing the one that's in there.
  16. #135
    Mar 2014
    40
    196
    im still having trouble troubleshooting the ac compressor how do i test it?
    i bypassed the relay to engage the clutch it engaged but the compressor dident turn on.....
  17. Remove Advertisements
