new blower motor not turning on - Page 8
Page 8 of 10 FirstFirst 12345678910 LastLast
Results 106 to 120 of 147
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new blower motor not turning on in Past Cadillac Vehicle Discussion; Look at it and see if the clutch is engaging....
  1. #106
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
  2. #107
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    40
    196
    Re: new blower motor not turning on
    how do i know it is engaging
    is the clutch attached in front of ac compressor where the belt is attached to it?
  3. #108
    rodnok01's Avatar
    Feb 2012
    NC
    6,720
    Yes, with ac off it does not spin, when you turn ac on it energizes the clutch and the compressor turns. If i get to my computer i will post link to my bad ac compressor so you can see exactly what it looks like.
    https://www.flickr.com/photos/rodnok1/12756700675/
  5. #109
    Mar 2014
    40
    196
    Quote Originally Posted by rodnok01 View Post
    the cluth did not spin when i turned on the ac..
  6. #110
    rodnok01's Avatar
    Feb 2012
    NC
    6,720
    Do you have any codes?
    There is an AC compressor relay under the hood you might want to swap with another and see if it comes on.
  7. #111
    Mar 2014
    40
    196
    no codes
    i checked the relay its good.
    does the system have to have Freon in it for the compressor to operate?
    also the heater doesent work.. i disconnected the outlet hose at the heater core where the water travels out the heater core and no water came out..what does that mean..
  8. #112
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes, there has to be refrigerant in the system. If the pressure gets low enough, a code is set, the compressor is disabled, and a message is displayed.
    If no coolant came out with that hose disconnected, either the system is low on coolant, or there are clogs.
  9. #113
    Mar 2014
    40
    196
    but i checked there is no codes displayed.. i think my system has no Freon in it.
    well im good on coolant.where could the clogs be..could that cause the heater not to work?
  10. #114
    69
    82,386
    If you are low on refrigerant and turn on the A/C, it will set a low refrigerant code.
  11. #115
    Mar 2014
    40
    196
  12. #116
    Mar 2014
    40
    196
    @ranger well if i have refrigerant in the system..
    what is the next step?
  13. #117
    69
    82,386
    You must be sure you have ENOUGH refrigerant. If you do, then the next step would be checking electrical connections, fuses, clutch etc. This of coarse is assuming you are talking about the compressor and not the blower as the title suggests (I haven't been following this thread real closely).
  14. #118
    Mar 2014
    40
    196
    how can i see if i have enough refrigerant..
    well i checked relay it was good, fuse was good, bypassed the relay by jumping terminals to engage the clutch and it clicked so i guess thats good..
    the blower problem is solved we are on the ac and heater system now
  15. #119
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    With the age of your vehicle and the fact that you haven't operated that system in quite some time, I'd write off the compressor and the drier.
    Personally, I would replace the compressor, the drier and the orifice tube and be done with it
  16. #120
    69
    82,386
    Quote Originally Posted by sean starks View Post
    By checking your high and low pressure readings with an A/C manifold gauge set. Or by having it recovered and weighed.
  17. Remove Advertisements
