new blower motor not turning on - Page 6
Page 6 of 10 FirstFirst 12345678910 LastLast
Results 76 to 90 of 147
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new blower motor not turning on in Past Cadillac Vehicle Discussion; Unfortunately Sean, Without me physically being there to see how you're connecting things, it's hard to tell. This thread had ...
  1. #76
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Re: new blower motor not turning on
    Unfortunately Sean,
    This thread had a similar issue, everything I've been telling you to do he has figured it out....
    http://www.cadillacforums.com/forums...wer-motor.html
    You are going to have to hand this issue off to someone that knows electrical work.
  2. #77
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    40
    196
    since it says repair 754 how do i repair it?buy a new programmer connector
  3. #78
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Circuit 754 is nothing but a wire from terminal D1 on the programmer connector to terminal B on the blower motor. That circuit may have another connector joining the one single wire to the blower motor.
    I suggest you stop.
    This isn't something for you to do.
    You need to take it to someone with electrical experience to solve this. I can guide you but you unfortunately don't have enough electrical experience to deal with this issue.
    You can make things worse......
  5. #79
    Mar 2014
    40
    196
    Quote Originally Posted by 98eldo32v View Post
    I suggest you stop.
    i can do this trust me..why dont i just replace 754 to see if it works doesnt hurt to try
  6. #80
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Sean you can't get your "new" blower motor to power up?
    Now you want to attempt to bypass a circuit?
    You could potentially ruin the car electrically......I suggest stopping.
  7. #81
    Mar 2014
    40
    196
    but awnser the question since the chart says repair 754 which part am i to replace
    blower motor never turned on when i first bought it brand new
  8. #82
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Sean,
    There isn't a part to replace. This is why it's called diagnosis. It's possibly the wiring or the connection. You're trying to throw parts at a problem and in the end it could be a loose connection somewhere.
    The programmer seems to have a very high failure rate, but it sounds like you have other issues going on with this car if the heater hasn't worked in 8 years of ownership.
    It's time to pass the baton to someone that can run with it........
  9. #83
    Mar 2014
    40
    196
    Sean,
    so then do i just give up ?
  10. #84
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    You unfortunately have to take it to someone that can understand the electrical diagnosis of the system.
    I suggest that you do before you make things worse......
    If you had more electrical experience, you would have figured this out already.
    It's not a bad thing. We all have our area of expertise...........
  11. #85
    Mar 2014
    40
    196
    @98eldo32v i mean i understand it i just dident get the whole ''jumping part'' i dident know if i was doing it right or if you were telling me the right directions.i got pretty far on that programmer chart i got all that got to the bottem..but i just dont get the repair ''754'' part..
  12. #86
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Sean,
    what needs to been done you don't have enough experience with, it can lead to bigger problems
  13. #87
    Mar 2014
    40
    196
    @98eldo32v its ok tell me what to do you have no worries
  14. #88
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    I'll be back in touch....
  15. #89
    Mar 2014
    40
    196
    Ok,
    Circuit 754 is the gry/black wire at pin B?!
    Which means you have a bad connector, pin in the connector at pin b or the wire connection is broken.
    Take a piece of wire and "jump" pin b from the blower motor back the terminal on the programmer.
    what was the jumping pin b of blower motor to back of the programmer procedure supposed to do..i think i found the problem..
  16. #90
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    When you "jump" pin B of the blower motor back to the programmer, you're by passing circuit 754.
    The jumper wire now becomes circuit 754. If the blower "now" works, you've found the problem.
    That circuit, and or the associated wiring is at fault.
  17. Remove Advertisements
