new blower motor not turning on - Page 5
Page 5 of 10 FirstFirst 12345678910 LastLast
Results 61 to 75 of 147
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new blower motor not turning on in Past Cadillac Vehicle Discussion; @98eldo32v can you see these charts?...
  1. #61
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    40
    196
    Re: new blower motor not turning on
  2. #62
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    That flow chart next to the schematic in post 59 tells you how to diagnose the issue.
    Follow the flow chart.........
  3. #63
    Mar 2014
    40
    196
    @98eldo32v that second chart is the procedure to diagnose the ac programmer.it says ckt repair 754.dont know what ckt means..but thats where im at at that chart
  5. #64
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Ok,
    Circuit 754 is the gry/black wire at pin B?!
    Which means you have a bad connector, pin in the connector at pin b or the wire connection is broken.
    Take a piece of wire and "jump" pin b from the blower motor back the terminal on the programmer.
  6. #65
    Mar 2014
    40
    196
    @98eldo32v hmm if it cant be the ground what else could it be the 350 wire or 1142 wire?
  7. #66
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Circuit 754 is the blower speed signal wire from the programmer to the blower motor, not a ground circuit.
    Circuit 1142, carries 12 volts, THAT'S ELIMINATED IF YOU HAVE VOLTAGE
    Circuit 350 is ground, THAT'S ELIMINATED IF YOU JOIN 1142, TO 350 WITH A TEST LIGHT AND THE LIGHT COMES ON.
    The only circuit in question is 754 and the data line.
    When you apply 12 volts to the blower motor and a ground does the motor spin?
    This is electrical diagnosis and this maybe a bit much for you to deal with. You may have to hand this over to someone that will understand the schematics and what I'm explaining, but it's really straight forward.
    Yet, you do something wrong, short circuits will sprout up fast.
  8. #67
    Mar 2014
    40
    196
    @98eldo32v what exactly is jumping if i may ask? i dont know what your asking.. to run a wire in pin b of blower motor to back of terminal of programmer.i dont think i got a wire that long enough
  9. #68
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    "Jumping" means basically bypassing the existing wire that completes that particular circuit with another wire.
  10. #69
    Mar 2014
    40
    196
    when i applied 12 volts to the motor it dident wanna spin .i bought this blower brand new like a month ago
    Quote Originally Posted by 98eldo32v View Post
    Ok,
    d
    also i have a fused jumper wire can i use that to jump pin b of blower motor
  11. #70
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    You're close to solving the issue or discovering the real problem, but you can do more harm than good to your car at this point if you do the testing wrong.
  12. #71
    Mar 2014
    40
    196
    @98eldo32v so can i use the fused jumper wirer to pin in to pin b cause thats all i have
  13. #72
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    I suppose you could.
    Plug everything in the way it should be.
    Take a piece of wire or the fused jumper wire and stick it in firmly at the rear of the connector on the blower motor at terminal B, take the opposite end of the wire/fused wire and stick it in the backside of the connector of the programmer in terminal D1.
    Then test to see if the blower motor engages.
    When you applied 12 volts to pin c, and grounded a on the blower, the motor didn't spin??????
  14. #73
    Mar 2014
    40
    196
    ok ima try this see how it goes.
    i tested it when i first installed it brand new it dident blow
  15. #74
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    How did you test it before you installed it on the car may I ask?
  16. #75
    Mar 2014
    40
    196
    well
    well i connected it and nothing happend.am i supposed to check with a test light or mutimeter?what does that procedure do?
  17. Remove Advertisements
