Page 4 of 10 FirstFirst 12345678910 LastLast
Results 46 to 60 of 147
Thread: new blower motor not turning on
  1. #46
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    40
    196
    Re: new blower motor not turning on
    @98eldo32v well none of the fan speeds went on went on when i selected them
    @98eldo32vnone of the blower speeds worked when i plugged it in
  2. #47
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    You are going to either need another vehicle to test the "new" programmer or get a hold of a factory service manual as stated above.
    The "new" programmer, there is no way to tell if it functions per se', unless you plug it into another vehicle that was fully functional.
    If the new programmer is good, you may have a fault in the instrument cluster
  3. #48
    69
    82,273
    Quote Originally Posted by sean starks View Post
    hmm where can i get em at i looked on ebay
    Forget Chiltons or Haynes
    http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
  4. #49
    Mar 2014
    40
    196
    @ranger since the climate control section is only in the #2 book can i buy the #2 book for 30$ and get away with fixing the blower motor
  5. #50
    69
    82,273
    Sure you can, but sooner or later you're gonna need book #1. I'd buy the set. They are worth their weight in gold and one usage will pay for it self. Best money you'll ever spend.
  6. #51
    Mar 2014
    40
    196
    ok i bought vol 2 for 25 buks not bad huh
  7. #52
    Mar 2014
    40
    196
    @98eldo32v @ranger how do i fix a bad ground and do i fix a bad wire because thats what it says it might be
    Attachment 201809 this is where its saying where the problem can be
  8. #53
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    I can't see the attachment for some strange reason
  9. #54
    Mar 2014
    40
    196
  10. #55
    Mar 2014
    40
    196
    @98eldo32v
    @98eldo32v can you see it
  11. #56
    69
    82,273
    Locate the ground, unbolt the wire, clean it up with a wire brush or steel wool so it has a good clean contact and bolt it back down.
    Quote Originally Posted by 98eldo32v View Post
    Me niether.
  12. #57
    Mar 2014
    40
    196
  13. #58
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    That link is a dud also.....
  14. #59
    Mar 2014
    40
    196
  15. #60
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    The picture came up.....in post #54..
    Remember when you jumped pin A to pin C incorrectly and noticed all those sparks, that's because you were taking 12 volts from pin C and grounding it out on pin A. That's what's going to happen if you don't use a test light correctly or have a load, in between the positive terminal and negative terminal.
    Not to say you don't have a ground issue, but I truly doubt it.
    You're having an issue through the cluster along the data line or in the programmer itself.
    Worst case scenario, the cluster has an issue....
    The picture in post 59, now appears
    If you truly believe you have a ground issue, run a separate ground test wire to pin A at the blower motor connection and test everything out.
  • You may not post replies
