new blower motor not turning on - Page 10
Page 10 of 10 FirstFirst 12345678910
Results 136 to 147 of 147
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new blower motor not turning on in Past Cadillac Vehicle Discussion; More than likely your ac compressor is seized...........
  1. #136
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Re: new blower motor not turning on
  2. #137
    sean starks is offline Cadillac Owners Fanatic
    Automobile(s): 1994 deville 4.9
    Mar 2014
    40
    196
  3. #138
    Mar 2014
    40
    196
    repalced heater core its blows hot air now
  5. #139
    Mar 2014
    40
    196
    ac compressor troubleshooting
    im trouble shooting my ac compressor ive already bypassed the ac relay to get the clutch to click on but the compressor does not turn on.and realy is good..cheked the fuse and it was good..i dont know where to go from there. thanks for your help much appreciated
  6. #140
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    Re: ac compressor troubleshooting
    Quote Originally Posted by sean starks View Post
    I just noticed that you started a new thread about the same problem -
    that is a BIG NO-NO -
    I'm sure one of the mods will merge your posts -
    have you checked for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    there are several built-in safety devices -
    that will prevent the compressor from engaging -
    if using a test light - or DVOM -
    do you have power at the compressor clutch?
    if YES - and the clutch IS engaged -
    the compressor might be seized -
    but I would expect the clutch to be making a LOT of noise -
    OR the clutch is burned out - and NOT actually engaging -
    even though it is receiving power -
  7. #141
    Mar 2014
    40
    196
    there is power at the cluth and it does engage.it just makes a normal clicking noise..so does that mean the compressor is seized?
  8. #142
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    no - if the clutch was engaged - and the compressor was seized -
    the clutch would be screeching like crazy - along with smoke and sparks -
    IF the clutch is engaged -
    and IF the compressor is NOT seized -
    you will see the compressor clutch pulley spinning -
    if you have by-passed all the "safety" measures protecting the compressor -
    the compressor might be turning - but NOT producing any cold -
    freon carries the oil that lubricates the compressor pistons -
    if you continue running the compressor without freon -
    you WILL seize it up -
  9. #143
    Mar 2014
    40
    196
    but is wasent screeching like crazy. i bypassed the ac clutch relay to see if the clutch gets energized and it did..
    the clutch would just click not spin.so what does that mean?
  10. #144
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    just to be sure we are talking about the same thing -
    watch this youtube video -
    http://www.youtube.com/watch?v=UvOFHexLTGU
    it shows an AC compressor clutch engaging - and disengaging -
    compare what you see here - and what yours is doing -
  11. #145
    Mar 2014
    40
    196
    well when i bypass the ac relay by jumping terminals 3 and 5 i think to clutch it just clicks but is does not spin like in the video..so i know its sending power to clutch..
  12. #146
    69
    82,383
    The clutch is shot.
  13. #147
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Back to what I had stated,
    Bite the bullet and replace the necessary parts......
  14. Remove Advertisements
