1999 Deville multiple misfires on #4 cylinder.
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 Deville multiple misfires on #4 cylinder. in Past Cadillac Vehicle Discussion; Hello, I have a 99 deville with multiple missfires on #4 cylinder. It has good spark and good compression. The ...
    Chris78 is offline Cadillac Owners Member
    Mar 2014
    3
    Hello, I have a 99 deville with multiple missfires on #4 cylinder. It has good spark and good compression. The injector looked like it may be clogged so I changed it. It still has multiple missfires. Not too sure where to go from here! It is also going from 194 degees to about 220 when sitting still. The electric fans are not kicking on. Just wondered if anyone has had this problem also. Thankyou for any help possible!
    rodnok01's Avatar
    Feb 2012
    NC
    6,634
    Re: 1999 deville multiple missfires on #4 cylinder.
    Probably have a bad coil or the plug is junk.
    Fans won't come on until @228 with AC OFF IIRC.
    If you turn AC on they both run slow speed.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    With no A/C (compressor) function set, fans go to SLOW at 224 and FAST at 236. With some A/C function set, fans run in SLOW all the time.
    The thermostat begins opening at 188 and is fully open at 206.
    If fans go to SLOW the engine cools to 213, fans shut OFF, the (slow traffic/idle) sequence begins again.
    Normal.
    Read the cooling system stickys in the Engines; Northstar forum.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Swap the offending coil with the one next to it, and see if the misfiring cylinder moves. Test the wires in the same way, too.
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast
    Automobile(s): Ex-99 Deville owner, Now-04 DTS and 05 DTS. ZX6R Pilot too.
    Nov 2005
    Upper Marlboro, MD
    34
    841
    Re: 1999 Deville multiple misfires on #4 cylinder.
    I would do as suggested and swap the coil over one and note if the misfire moves to the new cylinder. If misfire stays in the same cylinder, I would look at plug wires and boots. How many miles do you have? Those plug wires can crack down in the boot area and "leak" a spark to the engine block instead of the plug getting the charge. If you have a lot of miles, I would suggest new plug wires.
    Mar 2014
    3
    Hi. I have a 99 deville with multiple missfires on #4 cylinder. It has spark and good compression. The injector looked like it may have some gunk in it so I changed it. It still has the missfire. I'm not sure where to go next with this! Any help would be greatly appreciated! Thank you.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    you posted the same question - and received 4 responses -
    why post the same thing again? -
    one of the moderators will merge your 2 posts -
    http://www.cadillacforums.com/forums...-cylinder.html
    multiple posts
    Mar 2014
    3
    Thank you very much for the help everyone! I really appreciate it. I will try swapping coils. 99 Classillac, it has 51,000 miles. basscatt, I posted the first question but couldn't find it for some reason so I wasn't sure if it worked so I just posted again. Sorry about that. Thanks again everyone!
  11. Remove Advertisements
