1995 Deville electrical weirdness
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1995 Deville electrical weirdness in Past Cadillac Vehicle Discussion; If you've seen any of my past threads, I'm still battling random weirdness on my 95 Deville. It started with ...
    oregonk5 is offline Cadillac Owners Member
    Automobile(s): My 95 Deville, parents' 90 Fltwd Brougham. Many more!
    Jan 2012
    Oregon
    24
    It started with occasional failure of the dash HVAC fan to blow. Next was Traction Disabled warning light staying on. Later the cruise control started working intermittently and now is completely off. Now the Trunk Open warning light is on all the time.
    Throughout the process there has been a multitude of codes, most of these codes have to do with PCM communication failure. I've cleaned grounds, cleaned fuses, tried a different ECM, checked the EBTCM connections. So far nothing has changed.
    Anyone have any thoughts on this?
    RomoRock3r's Avatar
    RomoRock3r is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Deville Base
    Apr 2009
    NYC
    268
    Is the battery in good condition? A bad battery will cause glitches in the electrical systems.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yeah, what's the voltage reading on your DIC with the engine off? Preferably after being off for at least 30 minutes.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,180
    Re: Weird issues on 95 Deville...could it all be related?
    You may get more help in the front wheel drive section.
    69
    82,173
    Double Post
    Jan 2012
    Oregon
    24
    Re: 1995 Deville electrical weirdness
    No voltage readout option on the DIC. Just oil change life, etc. What are you thinking?
    Sep 2010
    East Boston MA.
    29
    26,325
    If you s roll through the DIC readouts, voltage isn't one of them?
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Not from the factory. That can be fixed, however.
    http://www.cadillacforums.com/forums...t-upgrade.html
    It's easy. I've done it on mine. It adds Battery Voltage, Engine RPM, and Coolant temp to your DIC display options.
    Jan 2012
    Oregon
    24
    So this morning I swapped out the battery with a spare and cleaned the terminals.
    Here's what happened:
    -Interior lighting still doesn't work
    -Drove for 5.9 miles..."cruise engaged" light comes on when button is pushed but cruise no-workey
    -At 5.9 miles "trunk open" and "traction disabled" lights came back on.
    When I got to work I did a quick code pull out of the CCC:
    P052
    I032
    I052
    T072
    T077
  12. Remove Advertisements
