93' Deville hot on 1 side cold on other
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 93' Deville hot on 1 side cold on other in Past Cadillac Vehicle Discussion; Hey Wes, heres the bump. I am trying to figure out the problem with my 93 deville's heat, hot on ...
    CadillacJack76's Avatar
    CadillacJack76 is offline Cadillac Owners Fanatic
    Automobile(s): 02 eldo collectors series, 98 eldo, 97 deville, 96+94 SLS,
    Oct 2003
    Long island New York
    40
    219
    Hey Wes, heres the bump. I am trying to figure out the problem with my 93 deville's heat, hot on passengers side cold on drivers side, checked all the usuall stuff, still can't figure it out!! Anyone else heard any solutions to this problem???
    Jack
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    I just did some poking around, and found a Technical Service bulletin that may be related to your problem.
    Some of the models listed above may exhibit excessive heat on the driver's right foot while little heat is delivered to the upper left side of the vehicle.
    There is a redesigned floor duct that is supposed to alleviate the problem. P/N 25617775
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    So now we have 3 threads with the same question?
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    I don't know if this has to do with any of this or not, but it takes a real long time for my car to warm up when it is cold outside, it will take about 10-15min of ideling before warm air comes out, or about 5-10 minutes of normal driving....... the hot air dosn't come out of the AC vents either, if I select defog, it comes out on top of the dash, and if I select auto it comes out in the middle of the bottom of the floor area.
    It is a pain, but atleast I wont be using the DeVille in the winter, so it shouldn't be that much of a bother.
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: 93' Deville hot on 1 side cold on other
    That could be your thermostat though. That heats the car up quickly for more reasons than just pasenger comfort. It prevents oil sludge and other nasty stuff. for the $5 or so bucks that it is, replace it, even if it's not the culprit it's a little more piece of mind (esp. with those fail-safe ones)
    Oct 2003
    40
    219
    Ok, fellas, here's the deal, I found the problem with the heat. That car has a split level (upper/lower) duct system in it, and the problem I was having was no heat on drivers side and lots of heat on passengers side.......that sounds like a mix door,right? Well it wasnt, right off the bat, I pulled the glove box out and felt around the heater box to make sure the core was hot. Well that was where I should have stopped, the box was hot, so I ruled it out, so today after many other things I decided for the hell of it, to pull the programer and the outside cover for the heater box off. When I got it all apart, I looked in there and the one mix door was all that controlled the heat to both ducts. So I started really getting pissed! I felt the heater core, and it was nice and warm, untill I started the car, then only the top half of it got steaming hot, and the bottom half was ice cold, and yep! You guessed it, the bottom part of the core supplies heat to the passengers side heat ducts!!!! So there ya have it, the half heat 91 & up mystery has been solved, I am sure there are hundereds of people having the same problem so I am going to spread the word about it. Anyhow, thanks for letting me pick your brains, I gotta go change a heater core.
    Jack
  9. Remove Advertisements
