SES Light Fuel system lean codes?
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, SES Light Fuel system lean codes? in Past Cadillac Vehicle Discussion; Hey guys thanks with the help on that iac valve seems to make her start up fast anyway anoher thing ...
    SGWORLDWIDE Guest
    Hey guys thanks with the help on that iac valve seems to make her start up fast anyway anoher thing popped up now I started her today and the ses light came on pulled the codes and got these
    p0171 Fuel Trim System Lean Bank 1 CURRENT
    p0174 Fuel Trim System Lean Bank 2 CURRENT
    figure these are what are causing it as there current aswell what u guys think and what does it mean
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Re: SES Light Fuel system lean codes?
    Large vacuum leak - either the PCV dirty air line, intake manifold overpressure valve or intake manifold to throttlebody connector Plenum. Discussed endlessly - fixes in Tech Tips.
    The Deville, right ?? (This is the Deville forum, but both your (intended) cars can have the same problem)
    SGWORLDWIDE Guest
    Yup the deville will look into it
    69
    82,162
    My money is on the plenum duct. Very common failure on the 2000+ motors.
    SGWORLDWIDE Guest
    Thanks ranger I'm going to check it out weird that after I cleaned the IAC valve now the ses light comes on and I got lean codes though start up feels much improved fires right up after u cleaned the IAC hopefully can find this problem
    69
    82,162
    When you check the plenum, be sure to flex it with your finger while spraying near the 6:00 position. Flexing it will open the rip if it's there allowing the spray to enter the intake and raise the RPM.
    SGWORLDWIDE Guest
    Okay got the problem figured out and fixed hopfullly first the o ring was missing on the IAC valve besides being dirty and second my mechanic found the intake manifold gaskets leaking causing the stalling rough start and idol high rpm and just lack of power while he was in there he changed the plenum duct as well 150 out the door parts and all
  10. Remove Advertisements
