Lower radiator hose cold
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Lower radiator hose cold in Past Cadillac Vehicle Discussion; The car is getting barely any heat and is running a little hot. The purge line is clear. The top ...
    txboifrozt's Avatar
    txboifrozt is offline Cadillac Owners Fanatic
    Automobile(s): 06 DTS Performance
    Jul 2009
    Dallas, Tx
    27
    273
    The car is getting barely any heat and is running a little hot. The purge line is clear. The top radiator hose is warm but the lower hose is cold to the touch. Also if you let the car idle it'll cool itself down it seems like. Could it be radiator or thermostat?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Re: Lower radiator hose cold
    Which car ?
    Define "little hot", and that lower hose won't start to heat up until well after the thermostat begins to open at 188. Outside air temperature ??? and do you have decent heat in the cabin ?? In cold weather that cabin heater will do a good job of cooling the engine all by itself. If the car is sitting there, idling from cold, then it's doubtful that any meaningful conclusions can be drawn - check stuff after at least 10 miles of driving.
    txboifrozt's Avatar
    Jul 2009
    Dallas, Tx
    27
    273
    01 Deville. The temperature is going above the half mark. There's little to no heat in the cabin with it all the way up on full blast. Shouldn't the thermostat open at the half mark? So the hose shouldn't be real cold if the thermostat is open. The hose from the thermostat to the firewall is also cold. The thermostat was changed last month with the water pump. The thermostat is aftermarket, maybe it's not opening?
    Feb 2006
    57,180
    If the thermostat was not opening you should have PLENTY of cabin heat. I'll bet the heater circuit is clogged or airbound.
    The gauge is supposed to move. Ever seen this ???
    txboifrozt's Avatar
    Jul 2009
    Dallas, Tx
    27
    273
    You suggest to remove the heater hoses and check for blockage?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Quote Originally Posted by txboifrozt View Post
    check the coolant level -
    the serge tank should be about 1/2 full -
    69
    82,402
    Is it flowing coolant?
    I assume that the WP belt is intact and spinning?
    txboifrozt's Avatar
    Jul 2009
    Dallas, Tx
    27
    273
    At the purge line, coolant barely flows at normal idle. If I raise the idle then it flows more. Should it be flowing thoroughly even at normal idle?
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    If purge line is flowing coolant, then it's good. The flow rate will raise as the rpm raises (the water pump spins faster). If it's sputtering air, then it means you have air trapped in the system and the cooling system is purging.
    Assuming that your 01 is a base model, you most likely have the digital dash, which is even more damped, the middle (4/8) indicates 187F-235F.
    Make sure you installed the thermostat correctly (not in backwards), with the hole at 12:00. Did your new thermostat look similar to the old one?
  12. Remove Advertisements
