2002 DTS - need front struts
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree5Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2002 DTS - need front struts in Past Cadillac Vehicle Discussion; I need new front struts. My question is what set do I get? I already replaced the rear active suspension ...
    DonRSD's Avatar
    DonRSD is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Escalade ESV
    Aug 2009
    South Florida
    36
    181
    Question2002 DTS - need front struts
    I already replaced the rear active suspension with a set of Monroe's. Now I want to replace the front.
    I'll lose the active suspension, but who cares. I already lost it in the back by buying some Monroe shocks
    What model struts will fit my 2002 Deville DTS with no additional assembly required?
    Also, will any service suspension warning come on?
    For the rear I DO NOT have a service message, nor am limited to 90 mph, as my mechanic put a resistor on the rear Monroe shocks.
    If a resistor is needed, what type of resistor?
    68
    81,914
    Re: 2002 DTS - need front struts
    You'll have to wire in a resistor for each of the fronts as well if you go with passive struts.
    DonRSD's Avatar
    Aug 2009
    South Florida
    36
    181
    Quote Originally Posted by DonRSD View Post
    OK. Thanks.
    What kind of resistor?
    What kind of Monroe struts (an all in one assembly) can I purchase that are a direct fit & possible match for the rear Monroe struts that were a direct fit?
    68
    81,914
    I think some of the strut kits come with the proper resistor, but I'm not that familiar with it (never had an active system). Bass has posted replacement struts many times though.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    OK. Thanks.
    for the front struts on your 02 Deville DTS -
    you have a few options -
    to remain "ACTIVE" - the only option now - is to replace with OEM ACDelco units -
    a much more "reasonable" choice is to convert to "PASSIVE" -
    and here we have several choices -
    depending on the condition of all the other components within the strut assembly -
    Monroe 90014 KIT - $211.11 - with free shipping -
    http://www.amazon.com/Monroe-90014-S...ype=automotive
    includes EVERYTHING - except new springs - for BOTH sides -
    the next choice is the "QUICK STRUT" -
    Monroe 171685 - $124.05 - each - with free shipping -
    http://www.amazon.com/gp/product/B00...A1ATZ3MAARQNEF
    this is the entire strut assembly - INCLUDING new springs -
    and it is already completely assembled - which will reduce the labor -
    NOTE - the coil spring included is based on the DHS/BASE model Deville -
    somewhat "softer" than the coil spring in the DTS model -
    in your particular case -
    your DTS has stiffer coil springs than the DHS and BASE models -
    you may want to keep the stiffer springs - or maybe not - the choice is yours -
    if you DO want to keep the stiffer springs -
    and you need the bearing plates - etc -
    go with the first choice - the 90014 KIT -
    OR - if all the other strut components are in good shape -
    just buy the bare strut -
    Monroe 71685 - $58.35 - each - with free shipping -
    all three choices use the same great strut -
    whether it comes in the 90014 kit -
    the 171685 QUICK STRUT -
    or the bare 71685 strut -
    DonRSD and 94 sedan base like this.
    DonRSD's Avatar
    Aug 2009
    South Florida
    36
    181
    Quote Originally Posted by basscatt View Post
    THANK YOU SO MUCH!!!
    Your info was described perfectly and made perfect sense to a "non car guy" like myself.
    As far as resistors, what kind to I ask for at Radio Shack?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    4.7K ohm, 1/2 watt resistors. A 5 pack costs $1.19 last I checked.
    DonRSD likes this.
    5280's Avatar
    5280 is offline Cadillac Owners Member
    Automobile(s): 2000 Deville DTS, 2005 Suzuki GSXR 600
    Dec 2013
    Denver
    61
    I have a 2000 DTS and replaced my old struts with KYB's. They're stiffer, and I like it that way. Handles great, and I'm satisfied.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    RadioShack #271-1124
    DonRSD likes this.
    DonRSD's Avatar
    Aug 2009
    South Florida
    36
    181
    How are the resistors put in?
    DonRSD's Avatar
    Aug 2009
    South Florida
    36
    181
    Ok. Struts are installed, but now I get speed limited to 90 / service suspension system.
    Any help!!??
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Any help!!??
    check for codes -
    did you install the resistors?
    DonRSD's Avatar
    Aug 2009
    South Florida
    36
    181
    check for codes -
    Dont know how to install the resistors.........
    How would I install them?
  16. #14
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast
    Automobile(s): Ex-99 Deville owner, Now-04 DTS and 05 DTS. ZX6R Pilot too.
    Nov 2005
    Upper Marlboro, MD
    34
    841
    Monroe makes active shocks and struts for the DTS's too.... ACDelco's aren't the only maker. But, Monroe actives still aren't much cheaper. But they seem to last longer than the ACDelcos. The 04 DTS has 110K miles on the Monroe struts and it feels like my 05 DTS with ACDelcos with 77K miles. My original Delco struts on the 04 only made it to 68k miles before they started leaking. I fell lucky my 05 struts havent started up already. I'm going to go with the active replacements though. I love active suspension.
  17. #15
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    the "quick and dirty" method -
    hold the actual resister between your thumb and index finger -
    bend the two wires into a "U" -
    stick the two wires into the plug that the struts and shocks used to plug into -
    wrap with electrical tape -
    or better yet - use heat-shrink tubing -
    to hold the resistor in place - and waterproof the connection -
    and be sure the wires don't touch each other -
    the resistors take the place of the original electronics
    in the original struts and shocks -
    they have no function - other than "fooling" the suspension computer -
    into believing the electronic struts and shocks are still there - and working -
    Quote Originally Posted by 99Classillac View Post
    Monroe USED to make "ACTIVE" struts and shocks -
    they are no longer available -
    actually - yes - they are - if you want to stay "ACTIVE" -
    DonRSD likes this.
  18. Remove Advertisements
