fuel Gauge question (here we go again!)
Results 1 to 13 of 13
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, fuel Gauge question (here we go again!) in Past Cadillac Vehicle Discussion; ok, i need some help folks. I own a 98 deville concours. the gas gauge is like stuck at empty, ...
    natashakerenski is offline Cadillac Owners Member
    Automobile(s): 1998 Deville Concours
    Feb 2014
    Hurricane WV
    42
    5
    Smilefuel Gauge question (here we go again!)
    ok, i need some help folks. I own a 98 deville concours. the gas gauge is like stuck at empty, and shows low fuel on the dash. here is what I have done so far. Today, I had a brand new fuel pump module installed in it. The car runs stronger, but the gas gauge still doesnt work. the wiring at the tank is in great shape. so its not the sending unit or wiring there. just need some help or guidance wih this. any help will be appreciated.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,362
    Re: fuel Gauge question (here we go again!)
    this is a long shot - but worth trying -
    disconnect BOTH battery cables -
    and touch them together for a few seconds -
    then re-install the cables -
    ALWAYS disconnect the NEGATIVE cable first -
    and re-install the POSITIVE cable first -
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    Shall we assume the gauge worked at some point?
    Sounds like that new assembly is suspect.
    68
    81,897
    Where did the new pump assembly come from?
    Feb 2003
    california
    69
    6,627
    On most GM cars if the gauge stays on empty, theres a wire grounded (touching metal) somewhere in the harness to the tank. If it stays on full, theres an open connection in the harness.
    Feb 2014
    Hurricane WV
    42
    5
    ok. more info for you guys. new assembly is a brand new gm unit from my local dealer. the gas gauge didnt work when I got the car. so, at the advice of some of the posts here, i replaced the unit as a starting point. it still doesnt function. when i clear the pzm codes, the gauge goes to full, sits there and then im back to empty again. so...im at a bit of a loss. this has to me the most complicated car I have ever owned.
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    What codes do you have with definition and history or current?
    I can't remember if IPC or BCM deals with fuel level. The bcm does store avg mpg etc.
    Feb 2014
    Hurricane WV
    42
    5
    ok. i pulled the codes from it. i have a b0533, b1552, and a b1558 code in it
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,362
    Quote Originally Posted by natashakerenski View Post
    codes are meaningless without their definitions -
    and no one has them all memorized -
    Feb 2014
    Hurricane WV
    42
    5
    b1552 -- loss of keep alive memory
    b0533 -- deals with the sensor wiring itself
    b1558 -- deals with eprom checksum error
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    b0533 Fuel Sensor Open/Shorted To B+
    well it sounds like that would be the problem need fsm to figure out how to trouble shoot that one
    B1558 - BCM EPROM Checksum Error
    could be BCM is toast maybe caused by faulty pump or wiring. They run 30-50, maybe numbers fit, but a concours may have sepcific unit. check your number.
    Feb 2003
    california
    69
    6,627
    As I said.... If the gauge stays on E there's a shorted wire in the harness. Now you have an extra sender! Get it on a rack and trace the tank harness under the car. And yes these cars are complicated
    Feb 2014
    Hurricane WV
    42
    5
    well, i crawled under the car today since it was nice outside. inspected the harness and checked it. no shorts to ground, or b+ as described. but...with the harness plugged into the bcm, it showed shorted to b+. so, the bcm is the issue. got one on the way and will keep you guys posted. thanks for yalls help.
  16. Remove Advertisements
