Electrical Problem
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Electrical Problem in Past Cadillac Vehicle Discussion; I have a 1993 Cadillac Deville Sixty Special... Under the hood there are max fuses. The one that goes to ...
    Bryson City is offline Cadillac Owners Member
    Automobile(s): 1993 sedan Deville Sixty Special
    Mar 2014
    QuestionElectrical Problem
    I have a 1993 Cadillac Deville Sixty Special... Under the hood there are max fuses. The one that goes to the ignition switch is a 60 amp. When you go to crank the car, it blows that fuse. Any suggestions for a fix?
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    44
    10,021
    Re: Electrical Problem
    Love those 89-93 Sixty Specials! You may want to post your question in the FWD section for a better response to your problem, or a moderator will likely be along soon to move it for you. Good luck with your problem! Hope it get's sorted out quick!
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,263
    Quote Originally Posted by Bryson City View Post
    does it blow when you go to the ON position -
    OR does it blow JUST when you go to the START position?
    if it blows immediately in START position -
    it could be a bad starter switch -
    or a bad starter -
    more likely a dead short at the starter solenoid -
