Won't Shift Out Of First Gear
Results 1 to 15 of 15
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Won't Shift Out Of First Gear in Past Cadillac Vehicle Discussion; earlier this morning it worked i dropped the wife at work and went to go home and noticed my car ...
    domac89 is offline Cadillac Owners Member
    Automobile(s): 1994 Deville Sedan base w/4.9 w/ approx. 215k
    Dec 2013
    Grand Island FL
    4
    earlier this morning it worked i dropped the wife at work and went to go home and noticed my car wouldnt shift out of first gear, pulled the code and got a neutral safety switch, I just replaced the nuetral safety switch and still cant shift out of 1st gear, I can reverse and it hits all the gears when i shift but when i hit the gas nothing happens except when in drive when i can actually move, however i cannot get it past 27 mph. I dont know what to do, could a bad vacuum line be the cause i hear what sounds like hissing from a punctured tire when the car runs. Need serious help!!!!
    68
    81,755
    Re: PLEASE....need help!
    You might locate and repair that vacuum line first.
    P.S.
    I'm going to edit your title. "PLEASE....need help!" is not very descriptive.
    M3GATR@N's Avatar
    M3GATR@N is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Cadillac Sedan Deville
    Jul 2013
    Costa Mesa, Ca.
    41
    231
    Time for a tranny rebuild?
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If this is about the '94 in your profile, the transmission isn't vacuum controlled.
    So the transmission will shift through all fears if you shift manually?
  6. #5
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Re: Won't Shift Out Of First Gear
    4.9 has 4t60e trans. with 215k miles? a bad neutral selector switch would probably cause no start/crank, vs no shift.
  7. #6
    Dec 2013
    Grand Island FL
    4
    I can feel all the gears catch when i shift manually but still cant get past approx. 30 mph I can reverse just fine and can accelerate but when i hit 25 it starts winding down and loses power if i get rpms above 2200 it loses it grip so to speak and I can feel it slide back to nuetral but if i shift back to drive it wont catch so i have to turn off the car put it in park and start it and reshift all over.
    I think you might be correct as much as my wallet will not like it one bit.
  8. #7
    68
    81,755
    Quote Originally Posted by domac89 View Post
    Have you ruled out a clogged CAT?
  9. #8
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    SmileRe: Won't Shift Out Of First Gear
    This doesn't sound like a transmission problem. If you're hitting 25 mph in first gear, your engine would be screaming by then.
    Are you sure it is not shifting?
    Sounds more like a power loss issue.
    Okay, now that I reread your post, I'm not so sure.
    What do you mean, when you shift manually? How do you do that?
    Have you checked your transmission fluid level?
  10. #9
    Roycestroman is offline Cadillac Owners Member
    Automobile(s): 1993 deville
    May 2015
    33
    6
    Hey did you ever find the solution to your caddy cause mine is doing the exact same thing
  11. #10
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Is the trans getting vacuum?
  12. #11
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    does it have the 4.9 has 4t60e trans like stoveguyy said?
  13. #12
    mc_marto's Avatar
    mc_marto is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Cadillac Sedan deVille
    Aug 2011
    Fort Smith, AR
    27
    507
    Like MoistCabbage pointed out the 4T60E is electronically controlled. There is a vacuum line that runs to it, but it's for the modulator. If that line was leaking you'd most likely have harsh shifts but it'll still be shifting.
    When you say you can feel the gears engaging when moving the shifter to different positions you're feeling the 1st gear engagement in all of them. There is a transmission override that you can use for diagnosis. I don't know if it'll be the same override on your '94 deVille but on mine it's E.6.1. While in this override the transmission can manually be up and down-shifted. To access the override enter diagnostics, when 7.0 is displayed press Hi once (E.9.5 should appear IIRC), press Econ + Warmer, and then use Hi or Lo to navigate to E.6.1. When you get to the override you can put your car in drive and use Warmer to upshift and Cooler to downshift. The transmission won't downshift to first gear if above 30mph or 2nd if above 60mph. I believe the engaged gear was displayed on the FDC.
    Edit: I missed a step in the process of navigating to the transmission override. Please, read the steps again!
  14. #13
    Dec 2005
    288
    this is a long shot but one time I had a similar issues with my transmission. turuned out the electrical connector in front of my Trans was shorting out the one by the vacuum module. I did a quick test, I completely unplugged it took for a spin and she felt normal again. so I knew that was it repaired short and she doing fine now.
  15. #14
    Osheataylor1 is offline Cadillac Owners Member
    Automobile(s): 2004 DTS
    Aug 2016
    SE Michigan
    23
    1
    Hey, I have an 04 caddy DTS with the same problem, did you find a solution to this problem. I need help
  16. #15
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    The thread has been dead for just over a year. Your car has the 4T80E transmission, not the 4T60E as discussed in this thread. Different transmissions.
    Post your own thread, here in Deville, stating your problems and any diagnostic trouble codes found in the car's built-in scanner/reader.
    Welcome to CF!!!.............
  17. Remove Advertisements
