Results 1 to 9 of 9
Thread: 1995 Deville headlight question
    rayjuswa is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Deville
    Jan 2014
    Johnstown, PA
    68
    139
    I own a 1995 Deville that just turned 60,000 miles.
    Love the car and plan on keeping it.
    My question, my low beam headlights don't throw enough light.
    I would like to upgrade if possible.
    I would appreciate any and all options
    As t already said, I plan on keeping this car so I'm not afraid to put a few bucks into it.
    Within reason , or course.
    I have other questions that I will post separately to avoid any confusion (on my part)Ray J
    69
    82,273
    Re: 1995 Cadillac Deville 4.9l engine headlight question
    I think your best option is to simply put higher output bulbs in it.
    P.S.
    I edited your title. ALL '91 - '95 Devilles have the 4.9 engine so no real need to post it in the title.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,692
    stick with a high quality halogen bulb -
    do NOT even consider one of the HID conversion kits -
    YES - HID puts out more light -
    but the light will be scattered - resulting in LESS useable light on the road -
    if your headlights are not perfectly clear -
    as in "sand-blasted" - "cloudy" - or "yellowing" -
    you could try restoring them - the 3M kit is the best -
    there are several videos on youtube -
    showing how it works -
    or you could but new headlights - for around $100 each -
  5. #4
    Jan 2014
    Johnstown, PA
    68
    139
    What about just changing the bulbs
    It was suggested that I get Sylvania Ultra light bulbs for both the high and low beams.
    Has anyone got any info on whether these bulbs will brighten up the night?
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,692
    Quote Originally Posted by rayjuswa View Post
    those - and PIAA are popular - but expensive bulbs -
  7. #6
    69
    82,273
    They certainly should help some.
  8. #7
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,476
    Re: 1995 Deville headlight question
    With decent quality bulbs and not going to ultra ones the headlights should be decently bright. If there's nothing wrong with the headlights causing the problem like bad lenses or reflectors maybe there's a power drop somewhere causing it.
  9. #8
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Stepping up in bulb price doesn't usual mean more output, it means a higher quality, longer lasting bulb.
  10. #9
    Jan 2014
    Johnstown, PA
    68
    139
    I will check for bad lenses and/or reflectors again
    Also, I will test for power drop
    I'm assuming that my meter should be reading 12 volts at the connection.
    Is there any other way to check?
    Maybe at the fuse box?
  • You may not post replies
