Water Pump Lifespan
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water Pump Lifespan in Past Cadillac Vehicle Discussion; Greetings, As you know the head gasket repair and engine reseal on my '02 DHS is well underway at the ...
    markmnj's Avatar
    markmnj is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Cadillac Hearse, 2002 Cadillac DHS
    Oct 2013
    Hampton Township, NJ
    269
    Water Pump Lifespan
    Greetings, As you know the head gasket repair and engine reseal on my '02 DHS is well underway at the shop. Is it wise to replacing the water pump at 88K miles as a preventative step? How long do these pumps usually last?
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Re: Water Pump Lifespan
    You have the new style cover so I wouldn't replace it myself. And if it does need changed down the road it's easy to do anyways. If you had 150k I might say yes. The water pump idler pulley on the other hand I would change, when they go the take the cam pulley out. For $25-30 it's a five minute job esp since you have engine out. Add a belt for $10.
    markmnj's Avatar
    Oct 2013
    269
    Thanks, the belts and idler pulley's have been replaced around 1000 miles ago
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,215
    It's mechanical. Anything can fail tonight or in 2024............ just depends on how anal you are.
    68
    82,064
    Quote Originally Posted by markmnj View Post
    There is no "usual". Mine is at 106K and everything except the tensioner pulley is original and the only reason I changed it was because I had to change my daughters at 140K and figured I may as well order 2 and do them both. Hers needed it, mine did not.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    The shaft seal should be the concern regarding this discussion, and in the scope of the seal, age is a concern, not mileage. Frankly, I think the 12 year old seal justifies a "while-you-are-there" replacement. At this point, it (and anything else gasketed/sealed) is likely to fail sooner than later - and if you are pumping in the resources to do a HG job, I would assume you plan to keep it for some time...
    markmnj's Avatar
    Oct 2013
    269
    So it looks like my baby is coming back home tomorrow. I spoke to the shop owner today. Caddy is back together but he discovered while road testing today that I have a bad ignition control module on what would be the right bank coil pack. New coil pack with module to be installed before I get there tomorrow (the only way he can get it from his distributors). I'll bring the bad one home, replace the module and call it a spare. Other than that repair was a non event. No more HG issues and no more stinky oil leak.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Northstar water pumps aren't really complicated, if they spin without leaks, they work. I did not replace mine when I repaired HG on my 00 because it looked new. It's still working after three years, and it's probably 14 years old. I did replace one in my 99 because one of those cheap water pump socket ate it...
  11. Remove Advertisements
