Accessory problems, Windows, High Beam, Wipers Etc
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Accessory problems, Windows, High Beam, Wipers Etc in Past Cadillac Vehicle Discussion; I own a 99 Deville and im havin issuse. I just resently received a repair because my car was overheating ...
    Mrdeville93 is offline Cadillac Owners Member
    Automobile(s): 1999 Deville
    Feb 2014
    1
    I own a 99 Deville and im havin issuse. I just resently received a repair because my car was overheating due to the pullies melting and frozen water pump. Well after that i noticed my wipers stopped working. I changed the fuse and the motor but it did not help. Sortly after my windows would not let down, my stereo received no power, trunk and fuel button stopped working (valet switch was off) and my high beam would not switch on. I checked all fuses and so im sure it must be some sort of electrical problem but does anyone know anything i could try to fix this before taking it to a mechanic?
    rodnok01's Avatar
    Feb 2012
    NC
    6,673
    Re: Accessory problems, Windows, High Beam, Wipers Etc
    I would start by checking the fuse box for loose or corrosion under the hood.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,954
    Off to FWD
