Re: 95 deville questions I just went thru this a few months ago with my 95 deville.
The computer for the suspension is in the trunk. You have to access it to get the "flash codes". You probably have one or more struts that are not "responding", thus setting off the warning.
You can't get new electronic struts anymore.
To stop the "service ride control" message, I spliced a relay into the wiring harness to the suspension computer in the trunk. This tells the "driver information center" display that everything is OK with the suspension system.
Do a search here on "speed sensitive suspension", that's where I found the fix. It took about an hour to do it. |
