1999 deville hard shift lever
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 deville hard shift lever in Past Cadillac Vehicle Discussion; Seem my shift lever is getting harder and harder to move from P to anything. Worse in very cold WX ...
    MARINE64's Avatar
    MARINE64 is offline Cadillac Owners Member
    Automobile(s): 1999 Sedan Deville
    Jul 2013
    Kennesaw GA.
    69
    1
    and one else have this problem and what did you do about it?
    Appreciate any info..
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: 1999 deville hard shift lever
    Could be cable or MLPS(neutral safety switch).
    Pop the cable off at the trans & see if the shifter is free.
    If it is, MLPS.
    If not, cable.
    68
    82,062
    Before I installed the floor shift in mine it shifted rather hard. I removed the shifter, cleaned it up and lubed it with white lithium grease. It slides like a hot knife through butter.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    It's a common problem on the 94-99s, there have been several posts about it. It's the cable that gets gummed up with old grease and is only really affected by cold weather.
  7. Remove Advertisements
