2001 Deville - blown woofer
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 Deville - blown woofer in Past Cadillac Vehicle Discussion; Is there an aftermarket replacement that is a better choice than OEM? Anyone who has swapped one? thanks...
    Joe_B is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Feb 2014
    44
    thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    Re: 2001 deville sub woof - blown
    Depending on the grade of sound system install, replacing the woofer (it's NOT a subwoofer) is either a simple swap or a dedicated remake of the whole system. Surf through Audio, Video, Security for insight. If the system is a Bose, then that's what gets replaced - oddball hookup and impedance.
    If you're looking for more "woof !" as opposed to (or to replace) a blown OEM speaker, then there are hoops to jump through.
    The OEM head unit is part of the car's TheftLock and serial data bus systems. It's programmed with THAT car's VIN.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: 2001 Deville - blown woofer
    Quote Originally Posted by Joe_B View Post
    thanks
    if you are looking for a new OEM speaker -
    GM 9376880 is a great replacement - $76.88 - with free shipping -
    http://www.amazon.com/ACDelco-937688.../dp/B000K00DJ8
    Feb 2014
    44
    Thanks guys, - I'll go simple and order amazons.
    Avaya is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville DTS
    Jan 2014
    Iowa
    135
    Of all vehicles to add an amp and subwoofer, this is probably the easiest. The battery is close, the fuse box is close for remote turn on, and you have signal (going to old woofer). The only hiccup I"ve read about is keeping resistance on your signal wires, otherwise the stock amp shuts off the signal. You will also need either an amp that takes high power input, or converters to go from high power to RCAs.
    Feb 2014
    44
    Thanks Avaya
    I'll keep this in mind.
  9. Remove Advertisements
