1999 DeVille - hard to shift out of Park
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 DeVille - hard to shift out of Park in Past Cadillac Vehicle Discussion; It is hard to shift out of Park to go into Reverse or Drive. Is it the shift cable or ...
    bigchuck is offline Cadillac Owners Member
    Automobile(s): deville
    May 2010
    23
    It is hard to shift out of Park to go into Reverse or Drive. Is it the shift cable or something in the Column or Trans?
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: 1999 DeVille - hard to shift out of Park
    Are you parking on a grade? If so, your parking pawl is taking all the weight of your car to hold the vehicle in park. It's a small transmission part that engages mechanically (locks into a physical gear) when your shifter is moved to Park(P). Holding a vehicle with the parking pawl only on any grade is not good for the parking pawl itself and it will make you put more effort to release it from the parking position. Always engage your parking brake first before releasing foot brake after shifting to park.
    May 2010
    23
    No. It is even hard just park in the garage. It has always been easy but the last couple of weeks it has been hard to put into gear, especially when you try to put it into reverse or drive from Park! I am going to remove the cable from the gear shift and trans and see if that is my problem. I will check the column first to see if the shift lever moves easier. If it does, I will remove the cable from the Trans and check the cable for binding. Nothing has been done on the Shift column or anything removed or replace in the engine compartment to cause this. I would appreciate any information on this problem!
    spotty is offline Cadillac Owners Fanatic
    Automobile(s): 96 Concours, 05 DHS
    Oct 2006
    119
    I had this problem a few years ago on our 96 Deville (probably 200K miles at that point). The design is probably similar. In our case, it turned out to be a stuck shift cam on the steering column. It's located on the top of the column about a foot down from the steering wheel. I'm going from memory but as I recall, the cam pivots on a steel sleeve that is knurled on top. On ours, the cam was binding to the steel sleeve. I think the sleeve unscrews from a post, but it was a real pain to get off because it was stuck to the cam. The steel sleeve is about 1/2 in diameter and maybe 1/2 inch long.
    I was not able to find a new replacement sleeve (probably a $2 part when they were available) so I had to call salvage yards, who all wanted to sell me a complete steering column. I did find one guy who grudgingly sold me one for $50 or so. If I had to do it again, I'd consider trying to trim the old sleeve on a lathe. I made sure to grease the replacement sleeve before reassembling the cam to the steering column.
    rodnok01's Avatar
    Feb 2012
    NC
    6,632
    I might take my 97 apart Spotty and look for this issue when I look into this soon, it's been hard to shit since I got it. Not crazy hard but harder than it should be.
  8. Remove Advertisements
