Shifting out of park issue
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By rodnok01
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Shifting out of park issue in Past Cadillac Vehicle Discussion; I am new to this great forum and posted my first question this morning. I got some very well intended, ...
    Taz456 is offline Cadillac Owners Member
    Automobile(s): 2005 Deville DTS
    Jan 2014
    Pittsburgh
    46
    14
    I am new to this great forum and posted my first question this morning. I got some very well intended, educated answers so I thought that I would post this next question to all of you as well.
    Shortly after purchasing this 2005 Deville the interlock that allowed to shift out of park failed. Once I found out how much the part was I found a piece of tin and drilled holes into the corners of the piece of tin. Next I found a way to wire tie the tin to a piece of the mechanism that blocked the interlock from entering into the locked position.
    Is this how everyone dealt with this issue or was there some other way of handling it.
    For the record, the only other issues we have had since we purchased this a few years ago was the passenger window track I replaced, and the tires slowly leak. I had them scraped and brushed clean which worked for about 6 months and then they started to leak again. The leak worsens in the cold winter months but I have a compressor so not really a big deal.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,358
    Re: Shifting out of park issue
    Quote Originally Posted by Taz456 View Post
    GOD - I hope not - but you were just kidding - right?
    diagnose the problem - then fix it properly -
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    A used Interlock can't be much more than 20.
    As for the rim leaks they can apply a sealant when they mount the tires.
    Avaya likes this.
    68
    81,894
    I think the DTS has an orange manual release button under the rubber pad in the cubby hole in front of the shifter.
    I never connected it when I installed the DTS console in my DHS.
  7. Remove Advertisements
