O2 sensor locations on 98 Deville Concours
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, O2 sensor locations on 98 Deville Concours in Past Cadillac Vehicle Discussion; I am getting a p0143 code indicating o2 sensor circuit low volts bank 1 sensor 3. Where is this sensor ...
    millerconcourse is offline Cadillac Owners Member
    Automobile(s): 98 deville concourse
    Jan 2014
    brogue pa
    1
    I am getting a p0143 code indicating o2 sensor circuit low volts bank 1 sensor 3. Where is this sensor located and is it something a novice mechanic could replace?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Sensor 3 is after cat. U need to get under car. If you have warm garage or car lift its not hard. The sensor harness is secured behind thin sheet metal guard. Buy an acdelco sensor. Not a no name brand
    68
    81,731
    Re: o2 sensor locations on 98 deville concourse
    Quote Originally Posted by stoveguyy View Post
    Bank 3 is sensor behind cat. U need to get under car. If you have warm garage or car lift its not hard. The sensor harness is secured behind thin sheet metal guard. Buy an acdelco sensor. Not a no name brand
    I think you mean Bank 1 Sensor 3
