Check Oil Level message in DIC
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Check Oil Level message in DIC in Past Cadillac Vehicle Discussion; On my 04 dhs approx. between a month and two months after getting an oil change my check oil level ...
    GM_Ridin' is offline Cadillac Owners Fanatic
    Automobile(s): 2004 cadillac deville dhs
    Jan 2012
    san diego
    26
    366
    On my 04 dhs approx. between a month and two months after getting an oil change my check oil level comes on and sure enough my oil is low. Are our cars known for burning oil quickly or do I have a bigger problem I need to look into?
    MoistCabbage's Avatar
    MoistCabbage is online now Cadillac Owners 10000+ Posts
    Automobile(s): Crimson 2001 Seville STS, 1990 Seville (RIP)
    Sep 2010
    East Boston MA.
    26
    18,663
    2 years here and you've never read anything on oil consumption? Yes, some oil consumption is normal. If it's excessive, some WOT will likely help (this is in the Technical Archives).
    By the time you get the oil level warning, you're 2 quarts low... I take it you aren't checking your oil level regularly?
    Submariner409's Avatar
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    74
    41,573
    Re: check oil level
    Sounds like this is a car that has to scream "Help !" before the hood gets opened.
    GM_Ridin'
    , You're supposed to open that hood every week and look at, measure, touch everything.............. or one night, the thing you didn't check is going to crap out and leave you stranded in the boondocks. Do you manually check your tire pressures at least monthly ?
    Please go way up ^^^ to the top black bar and study the entire Cadillac Technical Archive. There are two articles on oil, oil life, and consumption that you NEED to read. GM says an acceptable oil use rate is one quart in 2,000 miles. Some Northstars use more oil than that, most use a lot less.
  5. #4
    Automobile(s): White Diamond '03 DHS (with floor shift)
    66
    70,376
    Re: check oil level
    I take it by "two months after getting an oil change" you did not do the job yourself. Do you know for a fact that they put the proper amount of oil in it?
  6. #5
    houg is offline Cadillac Owners Fanatic
    Automobile(s): deville
    Sep 2011
    54
    184
    Re: check oil level
    like he said
  7. #6
    Jan 2012
    san diego
    26
    366
    Yes I'm positive they put the proper amount which is usually around 6-8 qtz. No I did not do my own because currently where I live (condos) my HOA does not allow car repairs on property so its easy to go get it done down the street from my house.
    Thanks I need to look into this. Yeah I know I feel guilty I haven't read all the archived stickies with helpful info I'm just always so biz so when I tell myself I'll get around to it I never do lol.
    Quote Originally Posted by Submariner409 View Post
    GM_Ridin', You're supposed to open that hood every week and look at, measure, touch everything.............. or one night, the thing you didn't check is going to crap out and leave you stranded in the boondocks. Do you manually check your tire pressures at least monthly ?
    I check my fluids often but I'll admit I have been slacking a little because I definitely haven't been checking my fluids weekly.
  8. #7
    thenaaks is offline Cadillac Owners Member
    Automobile(s): 04 deville
    Jul 2011
    Middle Tennessee
    33
    58
    Around 6-8 quarts? If they only put in 6 quarts, you're starting out 2 quarts low.
  9. #8
    Sep 2010
    East Boston MA.
    26
    18,663
    Yeah, the proper amount is 7.5 quarts from empty, half way up the hash marks on the dipstick (xxxxxXxxxxx).
  10. #9
    dusty256 is offline Cadillac Owners Member
    Automobile(s): 1996 sedan deville
    Feb 2013
    59
    92
    Re: check oil level
    Quote Originally Posted by thenaaks View Post
    And 8 quarts is too much ... 7.5 is the spec ..I check mine every time I get gas . I never trust oil change places and would check the oil level my self before I moved the car or paid for the oil change.
  11. #10
    LynnBilodeau is offline Cadillac Owners Member
    Automobile(s): 2003 Deville DTS
    May 2010
    61
    17
    Re: check oil level
    I believe the owner's manual calls for 5w30. Any reason not to run something like 10-40 or thicker? Might slow down the oil consumption.
  12. #11
    Sep 2010
    East Boston MA.
    26
    18,663
    It won't affect oil consumption. Use 10W-30 if you feel the need for a thicker oil, but any -40 weight is too viscous at operating temperature
  13. #12
    Feb 2006
    74
    41,573
    Re: check oil level
    Yeah, that ^^^
    The Northstar engine oil lubricated bearing clearances are not set up for -40 oils in any sort of passenger car duty.
  14. #13
    Jan 2012
    san diego
    26
    366
    Yeah I think I'm going to start using 10-30 vs 5-30 to slow down the consumption. My car now has 140k on it so that may be another reason for the faster consumption. And after all of the trouble I'm going back to doing it myself. Hey has anyone switched to synthetic?
  15. #14
    Sep 2010
    East Boston MA.
    26
    18,663
    10W-30 is only more viscous when the engine is cold. It will make no difference.
    Yes, there are members using synthetic.
  16. #15
    Feb 2006
    74
    41,573
    Re: check oil level
    Yeah, that.
    The 5W-30 theoretically makes it easier for the engine to start and run during warmup - when the oil warms to about 160 degrees, any xW-30 oil is all the same viscosity. 5W- also gives a theoretical gas mileage increase when cold/cool (less drag in the engine rotating machinery) so that allows a tiny "improvement" in CAFE to satisfy the EPA for a while - until the bureaucratic fools come up with yet another "save us from ourselves" jackass idea.
    bigm57ict likes this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
