check oil level
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, check oil level in Past Cadillac Vehicle Discussion; On my 04 DHS this pops on after about roughly a month and a half to two months after getting ...
    GM_Ridin' is offline Cadillac Owners Fanatic
    Automobile(s): 2004 cadillac deville dhs
    Jan 2012
    san diego
    29
    414
    check oil level
    On my 04 DHS this pops on after about roughly a month and a half to two months after getting an oil change. Im not sure if I'm burning oil or if there's a leak. Has anyone experienced this and have pointers about it?
    kidzstang is offline Cadillac Owners Fanatic
    Automobile(s): '98 Cadillac Concours
    Jul 2007
    York, PA
    128
    Re: check oil level
    There is a good explanation in the tech tips but if you see no leaks (which are sometimes hard to find) then you are using it through the combustion process. This isn't bad per se'. Oil usage is much better expressed in mileage than in time; if you travel 1,000 miles per week, then your oil usage is probably about average..
    There are plenty of places for the oil to leak. Oil plug, oil pan gasket, cam cover gasket, oil cooler lines/connections, main seals.
    My question to you is why, considering that you are concerned about oil usage, would you rely on the oil level sensor? Why not lift the hood to check the dip stick (or does this car not have a dip stick; as the new Jag's have no oil dipstick)? I mean sensors fail.
    Cheers,
    Jack
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,634
    Re: check oil level
    The engine has an oil dipstick - use it to verify the possibility that the engines is or is not low on oil. The proper level is in the middle of the hashmarks - XXXXXXXXX - The "check oil level" message usually shows when oil has dropped to just about the very tip of the dipstick - 1.5 to 2 quarts low. Use the dipstick to set proper level; not some guess factor.
    69
    82,190
    Re: check oil level
    Quote Originally Posted by GM_Ridin' View Post
    Only one way to find out. Get under it and see if it is wet.
    Many people have. Read up on "Oil Consumption" up in the Technical Archives at the upper left (black bar) of this page. I think that is what kidzstang was referring to.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    And why occasional WOT operation is beneficial to your engine.
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Re: check oil level
    my dts goes through so much oil i wonder if oil changes are needed ... lol jk. i go through about 2-3 quarts per ~600 miles. though i would say about 80-90% of that leaks onto the ground.
    all Pre 2003.5 N* burn a bit of oil on avg. about one quart per oil change cycle, im not 100% sure about the 2003.5 and up N* Jake would know
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
    knotgoalie's Avatar
    knotgoalie is offline Cadillac Owners Fanatic
    Automobile(s): 04 DHS
    Oct 2013
    Ontario, Canada
    61
    279
    Re: check oil level
    My .02CDN...My 04 DHS is showing 30% oil life left and when I pull the stick/wipe/ insert etc., it shows to be not only full but dead clean to boot! No burning, leaking or use (215,000km)? No engine retains all of its oil btween changes so WTF?
    I don't have a long history with this car being that I purchased it Oct. 4th-13 but so far it seems to have dodged every potential bullet there might be involved with this engine (no complaints at all dear Karma) but the oil thing does puzzle me. Every engine depletes its oil supply to some degree or something is not right??? FWIW, it is my nature to never trust any machine new to me.
    J.R.
    Sep 2010
    East Boston MA.
    29
    26,325
    Oil life and oil level are completely unrelated.
    A small amount of oil consumption won't be easily noticeable on the dipstick.
    Feb 2006
    56,634
    Re: check oil level
    A good Northstar uses essentially no or little oil between normal changes. My STS engine goes over 7,000 miles/quart. The Ford 4.6s in the trucks go over 7,500 miles/quart (and the truck oil is 5W-20).
    I change my STS oil/filter each March, about 6500 - 8000 miles, and it drains out as a clear amber color. About 45 - 55 % on the OLM. The engine is NOT "babied" - I run the snot out of it wherever, whenever - and there's a big difference between exercising an engine and abuse.
    GM's Northstar oil consumption "desired" rate is 2,000 miles/quart or greater.
    knotgoalie's Avatar
    Oct 2013
    Ontario, Canada
    61
    279
    Re: check oil level
    Bear with me Sub, I'm learning the N*...my previous 85 SDV had the sucky but durable (for me anyway) 4.1 and the 04 is a learning curve to be sure. Little motor, serious power and a great car. There seems to be an exception to "if its too good to be true"...it is a fine running N* that does not seem to want to let me down!
    J.R.
    Sep 2010
    East Boston MA.
    29
    26,325
    Do my eyes deceive me? "4.1" and "durable" in the same sentence?
    knotgoalie's Avatar
    Oct 2013
    Ontario, Canada
    61
    279
    Re: check oil level
    You heard me, drove it, beat it, towed with it and it never failed me in the least. It was a low powered gas pig but it never broke down on me. I sold it because I never used it after we opened a business and I needed a truck (F150).
    J.R.
    Jul 2007
    York, PA
    128
    Re: check oil level
    Quote Originally Posted by Submariner409 View Post
    Agreed. Leaks seem to be more of a problem on my engine than "burning" it. Although almost negligible; mine loses about a quart every 3K miles; I change at 5K intervals. Once I fix the small leak at the oil cooler to engine fittings, finally remember to get a new oil pan plug and put a new rear cam cover gasket on it (a little bit of fuzzy oil); I expect virtually no oil loss over 5K miles.
  16. #14
    69
    82,190
    Re: check oil level
    Quote Originally Posted by 04GrandAmGT View Post
    At that rate I would not "change" it. You're flushing it at a slow rate. Just change the filter occasionally.
  17. #15
    knotgoalie's Avatar
    Oct 2013
    Ontario, Canada
    61
    279
    Re: check oil level
    Not to hijack, but could I be the only one with a 4.1 that actually worked? I don't think so. Yes, my 4.6 F150 or my 4.0 Jeep Cherokee could out-pull/out-run it but the damned thing never broke down...ever! 1985 SDV plated and registered Feb 12 84...dealer VP demo car.
    J.R.
  18. Remove Advertisements
