Check Engine Soon Warning on my 2005 DeVille
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Check Engine Soon Warning on my 2005 DeVille in Past Cadillac Vehicle Discussion; I recently bought my wife a new to her 2005 DeVille with 24,600 miles on the clock. She wanted the ...
    TerryA is offline Cadillac Owners Member
    Automobile(s): 2005 De Ville
    Jun 2013
    74
    37
    I recently bought my wife a new to her 2005 DeVille with 24,600 miles on the clock. She wanted the same model she had with 111,000 miles.
    Anyway it is basically still a nice car so I have been driving it. It now has 121,000 miles.
    Yesterday the "Check Engine Soon" light came on. The car runs fine and is getting between 18 & 19 mpg on regular gas. I don't think it is anything serious but need to know for sure.
    I could not pull up the codes and would like the sequence to use.
    Any help would be appreciated.
    Thanks in Advance
    Terry
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    Re: Check Engine Soon Warning on my 2005 DeVille
    Quote Originally Posted by TerryA View Post
    Thanks in Advance
    Terry
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    SGWORLDWIDE Guest
    Quote Originally Posted by basscatt View Post
    Hey bass u should make that your signature since u have to type it so much lol
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Lol. Yeah, I got really tired of typing my version of it .
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    Quote Originally Posted by SGWORLDWIDE View Post
    ya - I hate typing the same thing over and over and over and over -
    so - actually - I just copy/paste it from a text folder -
    along with -
    ELC function -
    active to passive struts/shocks -
    P0300 code -
    PURGE LINE -
    cooling system pressure test -
    BLOCK TEST -
    Crankshaft Position Sensors -
    diagnose AC problems -
    plenum duct -
    Deville window fix -
    my list of ALL the PROVEN effective mods -
    P0741 code -
    WHY HID's don't work in Devilles -
    and several others -
    SGWORLDWIDE Guest
    along with -
    ELC function -
    P0300 code -
    PURGE LINE -
    BLOCK TEST -
    plenum duct -
    P0741 code -
    Cheater lol anyway Speaking of hids my stupid ones decided for some reason tonight to stop working had them on turned them off then when I went to turn them on noting the parking lights go on but no low beams hid relay fuse looks fine so idk any idea? doubt both ballest or lights burned out same time there from the retrofit source so got warranty
    Jun 2013
    74
    37
    Thanks bass,
    I promise I won't be a PITA!!
    As you can see this is my first post on this forum.
    Since I now own 2 of these beauties I'm sure it won't be my last.
    I will check it out and see where it takes me next.
    Thanks Again
    Terry
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    Thanks bass,
    Thanks Again
    Terry
    the only PITA's are the overly "sensitive" and "excitable" type -
    that ask for opinions and hate the responses -
    ask away - that's what we are here for -
    you will be amazed with the number of knowledgeable members here -
    willing to share valuable information -
    we get the same questions so often - usually from "first-timers" -
    I just created a text folder with the "canned" responses -
    saves me a lot of time and typing -
    here are two links of particular interest for you -
    the Northstar engine forum -
    http://www.cadillacforums.com/forums...al-discussion/
    and the TechTips forum -
    http://www.cadillacforums.com/forums...lac-tech-tips/
    LOTS of good stuff in both -
    Cheater lol
    I would rather work SMART - than work HARD -
    Speaking of hids
    you are using HID's in your Deville?
    get a good set of halogens -
    they will put more USEABLE light on the pavement -
    and stop blinding oncoming traffic -
    SGWORLDWIDE likes this.
    SGWORLDWIDE Guest
    Cheater lol
    Speaking of hids
    I fixed em damn ground cable from right side was loose actually they are not blinding no one as there in the low beam slot behind the chrome disperse cap and leveled u can stand right in front of them and they wont blind u i tested them (the ones that blind are idiots who put them in headlights or fog lights with no disperse cap or old non clear frosted headlamps that scatter bad) plus there 4300K factory color no blue crap I had all kinds of halogens the good ones (Silverstars, PIAA) they don't last long because they burn to hot to make them brighter and whiter and at almost 30-50 a set it aint worth it got my kit from the retrofit source nice quality not ebay crap, i might be doing a projector retrofit soon as they also have the stuff for that right now im still getting her paint together working on the 3 step process and touch ups
    PS: regarding my post on that weird start up stall i cleaned the TB was filty in only a year and i got the fuel pressure check my guy says its fine so i don't know why she did that but im sure the TB cleaner will help with her fast idol and pulling with out applying no gas, imagine that a caddy that drives itself
    Jun 2013
    74
    37
    OK Guys,
    With the holiday interference I finally got out and ran the codes on my 2005 DeVille. Thanks to basscat.
    This was my 1st time and even with a warning to be ready I wasn't.
    Anyway here is what came up.
    IRC - U1016 History
    IPC - U1000 Current
    PCM- 4022 Current "Power Train Module"
    The last one appears to be the culprit.
    I hope I got the number right because I accidentally erased it before I had a chance to read it again.
    Maybe I will be lucky and it won't come back. HaHa!! Fat chance of that.
    Thanks
    Terry
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    I don't really know of a P4022 code, but it might be a P0422 ("Catalyst System Low Efficiency Bank 1") code (which should turn on the MIL as it's an emissions related code.) The U1016 is probably not an issue, but the current U1000 might be - see http://www.cadillacforums.com/forums...ipc-u1000.html - has some details on the implications of that code.
    P0422 (if that is it) will cause an inspection failure in an emissions controlled area, and might have backpressure implications from a damaged catalytic converter - if it is damaged in such a way as to restrict flow. More likely the catalytic converter is just old and the catalyst is not working as well as it is designed to - no MPG implications from that, just know that you're probably sending a bit more unburned fuel out that back than you should be (the other possibility is that the oxygen sensor is damaged, not the catalyst.) The only hope of "cleaning" a catalytic converter is to get it nice and roasty, and hope the contaiminants burn off.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    OK Guys,
    IRC - U1016 History
    IPC - U1000 Current
    Thanks
    Terry
    naif is correct -
    no 4XXX codes - "U" codes come and go quite often -
    take the car out for an extensive "test-beat" -
    to "clear it's throat" - do a few WOT's -
    Wide-Open-Throttle -
    Jun 2013
    74
    37
    Interesting on the PCM 4022 code since I recently passes CA smog (about 3 months ago) with flying colors.
    I will go out and drive the hell out of it and hope the code does not come back.
    I thought the U1000 code was related to just the radio. I will have to wait and see if returns also.
    Since I cleared the codes out I will have to wait and see what returns.
    If either of them return to quote Arnold "I'll be back"
    Thanks
    Terry
  16. #14
    69
    82,171
    I agree, P0422 sounds like a logical explanation.
  17. Remove Advertisements
