heated seat power consumption??
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Ranger
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, heated seat power consumption?? in Past Cadillac Vehicle Discussion; 2003 deville, do the heated seats use much power? i use mine very little in fear that it tax,s the ...
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    367
    2003 deville, do the heated seats use much power? i use mine very little in fear that it tax,s the alternator too much and i dont want a premature alt failure?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    Re: heated seat power consumption??
    The electrical system and alternator are designed and built to handle any set of loads you can throw at them - as long as the loads are those in the as-delivered new car package.
    A non-issue.
    SGWORLDWIDE Guest
    yup would not worry now if some one put a different alternator in there then that's different think the stock one is 150 amps
    68
    81,926
    I'm not much of an electrician, but my understanding is that anything that produces heat uses a lot of electricity. By that I mean anything with a heating element as opposed to heat as a byproduct. That said, I would not refrain from using it. Like Sub said, that's what it's designed for.
    SGWORLDWIDE likes this.
    SGWORLDWIDE Guest
    just like rear window defrosters
    The Donald is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville delagance
    Apr 2012
    Colorado
    210
    Use mine all the time in winter with no problems..Alt. was designed to handle every thing Cadillac put on the car and use them all at once if needed..
    Feb 2006
    55,910
    High beam headlights consume more "power" than both front seat heaters.
    guyslp Guest
    It is a very, very rare occasion when an alternator cannot produce all the power needed to operate virtually any and all options included on a car that are likely to be in use at one time.
    Were you to somehow able to get so much going that the alternator couldn't handle it, that's what the battery is for.
    Realistically, I've never known of a situation where the alternator and charging system on a stock car are working properly where the battery would even be called upon except when starting the car. There are plenty of times when the battery is fully charged, and the system knows this, that you're "throwing away power" that's not being used at that moment.
    I would have no concern at all about using heated seats along with the heater, stereo, lights, cruise control, and any other option at the same time.
    Brian
    68
    81,926
    Quote Originally Posted by guyslp View Post
    I fully agree.
    How would you ever know when or if the system was pulling battery power?
    guyslp Guest
    Ranger,
    If premise one is true, and you agree it is, how could premise two not be?
    I base this on the fact that the only time I've ever had, or known anyone to have, battery issues is either that the battery itself has outlived its functional life or there is a flaw in the charging system. If the charging system is keeping the battery fully charged and one is using a collection of options on a fairly regular basis, this clearly means that in almost any "normal" circumstance there is not only adequate power from the alternator to run everything but an overage to allow the battery to charge.
    I don't know, definitively, when or if the system was pulling battery power, but it can't be pulling it very often or much or the battery will run down, and quickly. I've had that happening recently when the charging power being delivered to a brand new battery was just under 13V and my options use included only radio and blower fan. I'm making what I think is a legitimate deductive conclusion. I guess other's mileage may vary.
    Brian
    Feb 2006
    55,910
    FWIW, in an automotive 12VDC electrical system, the alternator and voltage regulator are designed to handle the normal loads of that particular model and options package. It is fairly common to see 2 or 3 different capacity alternators within a single manufacturer model line if the option packages require more/less capacity.
    Think of the battery as a "spring" or "surge tank". You start the engine - that draws off some battery capacity (the action of starting slightly unwinds the spring) - the engine comes up to idle/fast idle speed and the voltage regulator excites. Voltage ramps up from battery voltage - say 12.4 volts after start - to a charging figure - somewhere around 14.4 to 15.0 volts. At the same time, alternator amperage is increased to actually charge the battery: drive lead sulfate off the plates and back into solution in the electrolyte - thus raising the specific gravity of the electrolyte. As the battery charges its internal resistance changes - this is sensed by the voltage regulator, which then ramps down amperage (to avoid boiling the battery) and, to some degree, voltage. At full charge the battery "floats" on the entire electrical system, acting as the spring to compensate for load changes from normal - you turn on a load, the voltage regulator senses the spike, and the regulator compensates amperage output to carry the load - the battery does not continuously run anything - it's a "spring", reacting to bumps in the system. Voltage regulators are set to supply somewhere in the neighborhood of 14.0 to 14.6 volts continuously, with little amperage, to maintain full battery charge and run the car loads.
    "But my headlights dim at idle !". Bad (failing) battery, poor terminal connections, poor regulator wiring/connections/electrical condition. (or a self-installed boombox system)
    Note the chart: A 'battery' of six 2.1 volt cells (our car batteries) is essentially dead when it shows an open circuit voltage of 11.9 - 12.0 volts. Surface charge only - no "guts".
    SGWORLDWIDE Guest
    that's why I don't mess with car electrics or install any after market eletrical crap like big stereos as u never know if the charging system can handle it then u got to go buy a better alternator
    68
    81,926
    Ranger,
    Brian
    I think you are misunderstanding me Brian. I am not saying premise #2 is not true. I'm simply saying you won't know when it is.
  16. Remove Advertisements
