Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Shazaam! 1995 Deville DIC instant "upgrade"
  #76 (permalink)
Old 03-13-07, 07:17 PM
Cadillac Owners Enthusiast
Cadillac(s): 1995 Cadillac Sedan Deville- 4.9 Litre
View pompste's Photo Album
Casino Cash: $9136
Smile Re: Shazaam! 1995 Deville DIC instant "upgrade"
Originally Posted by Kdirk View Post
Hmm,
You must have one of the rare 95's with a heated windshield. With that option, the cluster gets the auto and econ buttons combined as one instead of having a seperate button for each function (so pressing it toggles whether you get auto or econ mode).
What is normally the auto button on models without the heated windshield gets reconfigured for the heated windshield on/off buttton. I'm not sure how this affects the option programming procedure, as I have not run across this setup myself. The factory service manual doesn't make any mention of the procedure being any different regardless of the cluster setup with or without heated windshield.
In any case, you should be able to back out of diagnostics by repeatedly pressing the OFF button several times until the cluster returns to normal operating mode. I have done this and it works, you just have to press it several times as opposed to hitting auto once to exit.
KDirk
Thanks for responding,KDirk,---you`re correct,i do have the heated windshield button.I have a soft-ray UNheated windshield now since the original heated one needed replacing and the heated ones are`nt produced anymore.
I went into the diagnostics anyway and got as far as the "nnn ISO7",waited a bit and the "nnn" came up "015" not the "016" i was looking for.Since you`re instructions state "if you have something other than "000" or "016" you may not want to change anything until you post it in the forum" i backed out by turning the ignition off.
I don`t know if adding 32 to "015" would work or not,so i`m not changing anything until i get other information from you or another helpful member here on how to proceed.
Again,thank you for responding.
  #77 (permalink)
Old 03-15-07, 02:24 PM
Cadillac(s): 1995 Sedan Deville Spring Edition
View Kdirk's Photo Album
Casino Cash: $250
Pompste,
Yes, adding 32 to the existing value will add the additional items to your DIC display, as the option values are summed to provide the desired combination of features for the vehicle. This will give you a value of "047". Once entered, follow the remainder of the procedure as posted, and when you back out of diagnostics and cycle the info button, you should have the extra items shown.
FWIW, I originally posted the warning about other numbers in case someone had a strange variant or export version I wasn't familiar with, and wanted to avoid mess-ups that could cause unpredictable results.
If you have any other questions, post back.
KDirk
  #78 (permalink)
Old 03-15-07, 05:42 PM
Casino Cash: $9136
Question Re: Shazaam! 1995 Deville DIC instant "upgrade"
Pompste,
KDirk
Thanks KDirk,one more question before i proceed.Since AUTO/ECON are toggled on the same button,will pressing AUTO/ECON and FRONT DEFROST together actually SAVE the "047" value?
Since pressing AUTO/ECON does NOT back me out of diagnostics,perhaps pressing AUTO/ECON and FRONT DEFROST won`t save the "047" value either.
I just want to be sure before i try this since as you mentioned,i have rare "015" number to start with along the toggled AUTO/ECON button,and one wrong entry could disable the vehicle.
I really appreciate the time you are taking to make this work.
  #79 (permalink)
Old 03-15-07, 09:01 PM
Casino Cash: $9136
Thumbs up Re: Shazaam! 1995 Deville DIC instant "upgrade"
Hi KDirk,no need to reply if you so choose.I got brave and went ahead with your great information and all went well!
I ve got to admit i was a bit nervous after i saved the "047" and then pressed the "OFF" button a few times to leave diagnostic mode.
I then pressed the information button and for the first time in 12 years i now have coolant temp. info,rpm`s,and battery voltage info along of course with the default info.
I can see why the Cadillac designers may have opted not to include the 3 extra data functions as default info.Since most Deville owners are "apparently" older drivers,they have to press the information button a few more times to exit information which takes their eyes off the road,if driving,and may take their concentration off the road just a bit too long and could lead to a mishap.I actually noticed this as i scrolled through the info as i was driving.As we all know,a lot can happen in a fraction of a second when driving.
I am glad to have this extra information and by the many other posts here reporting success by applying your information,i can see they are glad to have the added info also.
Thanks again for the detailed information!
  #80 (permalink)
Old 03-16-08, 03:15 PM
Cadillac(s): Cadillac
View SmiJ951's Photo Album
Casino Cash: $275
That is something that has irritated me for the 4 1/2 yrs that i've owned my sedan deville. please send me the instructions and i will use my own judgement if its something i wish to proceed with or not. i too, TAKE RESPONSIBILITY FOR MY OWN ACTIONS. thank you very much --Jim
  #81 (permalink)
Old 03-16-08, 08:18 PM
Cadillac(s): 94 Deville
View grgrose's Photo Album
Casino Cash: $815
I reset the DIC on my 94 DeVille about a week ago. No problems so far.
  #82 (permalink)
Old 03-16-08, 08:48 PM
Casino Cash: $9136
After a full year this thread has come to life again! The correct instructions for the DIC upgrade is the first post on page 3--by Kdirk.
The extra info is good to have---especially coolant temp.
  #83 (permalink)
Old 03-16-08, 11:15 PM
Banned
View CaddyCruisin420's Photo Album
Casino Cash: $1485
THANK YOU!!! im stoked
  #84 (permalink)
Old 03-17-08, 12:02 PM
Cadillac(s): 1997 Seville SLS
View boricuacaddy's Photo Album
Casino Cash: $2878
Easter is upon us! Time for dead threads to be ressurected!
David
  #85 (permalink)
Old 05-21-08, 12:57 AM
austinDeville's Avatar
Cadillac(s): 1995 Cadillac Sedan DeVille - 4.9L
View austinDeville's Photo Album
Casino Cash: $800
It was simple to implement and worked great on a 95 Deville with 4.9 engine. Thanks Kevin.
  #86 (permalink)
Old 06-07-08, 11:01 PM
hueterm's Avatar
Cadillac(s): 1995 Deville Concours; 2000 Eldorado ETC; 2004 Escalade EXT
View hueterm's Photo Album
Casino Cash: $17854
I've got coolant and voltage, but not RPM. (Not that I care about RPM...) Just wondering if I missed something.
CURRENT
1995 Deville Concours (1/2007-?)
2004 Escalade EXT (8/2007-?)
2000 Eldorado ETC (2/2008-?)
1970 Grand Prix Model J (4/2009-?)
FORMER
1992 Toronado (1995-1999)
1999 Grand Prix GTP (1999-2002)
2002 Avalanche North Face (2002-2004)
1993 Roadmaster (2004-2007)
2004 Avalanche Z71 (2004-2007)
1997 Riviera S/C (2006-2008)
FUTURE
1986-1991 Mercedes-Benz 560SEC
  #87 (permalink)
Old 06-07-08, 11:27 PM
dirt_cheap_fleetwood's Avatar
Redneck with class
Cadillac(s): 1990 350 Brougham (Its big), 1988 Mark VII LSC (Its fast)
View dirt_cheap_fleetwood's Photo Album
Casino Cash: $12600
You sure? On mine, RPM is the very first thing that shows up when I hit the info button from the blank screen. I just changed the value and it worked fine. Took all of 1 minute to do.
  #88 (permalink)
Old 06-07-08, 11:52 PM
hueterm's Avatar
Casino Cash: $17854
Nope, mine starts w/coolant temp, then volts, then the regular screens....oh well...at least I can make sure I'm not overheating.
  #89 (permalink)
Old 06-08-08, 12:51 PM
mrvspitbulls's Avatar
Cadillac(s): 03 Cadillac DTS Black on Black
View mrvspitbulls's Photo Album
Casino Cash: $3015
CAN this be done to a 2003 DTS ????
Still havent got an answer. Sorry
  #90 (permalink)
Old 06-08-08, 01:42 PM
hueterm's Avatar
Casino Cash: $17854
Why would you need to put onto a 2003 DTS?? You have an analog gauge...
Tags: , , , , ,
1995, deville, dic, instant, shazaam, upgrade
