DHS blower is dead how to diagnose and replace
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, DHS blower is dead how to diagnose and replace in Past Cadillac Vehicle Discussion; my 2004 DHS hvac blower is not working, checked the fuses, all work. what 's the next step to find ...
    sjnh_98 is offline Cadillac Owners Member
    Automobile(s): DHS,STS
    Dec 2013
    1
    my 2004 DHS hvac blower is not working, checked the fuses, all work. what 's the next step to find out the root cause? Thanks for any help.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,883
    Re: DHS blower is dead how to diagnose and replace
    Your post has nothing to do with Site Registration or News. Moved to Deville.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    Quote Originally Posted by sjnh_98 View Post
    actually - not an unusual problem -
    MOST of the time it's worn out brushes within the motor -
    which means simply replace it -
    SOMETIMES a good smack with the butt of a screwdriver may start it working again -
    for a very short time that is -
    SOMETIMES it is a ground problem -
    the ground connection is hidden behind the passenger kick panel -
    but typically you get a sporadic fan -
    works until you hit a bump - or make a turn -
    or stops working after hitting a bump - etc -
    RARELY - it could be a problem with the plug itself -
    inspect the connectors inside the plug for evidence of arching - or melted rubber -
    if it turns out to be the blower itself -
    you can save some $$$$$$$$$$ -
    I recommend the TYC 700110 -
    $40 - with free shipping - on ebay -
    http://www.ebay.com/itm/Buick-LeSabr...dd9b24&vxp=mtr
    or if you prefer amazon -
    $45 - with free shipping -
    http://www.amazon.com/TYC-700110-Pon...ype=automotive
    superawesome1's Avatar
    superawesome1 is offline Cadillac Owners Member
    Automobile(s): 2004 deville
    Oct 2013
    Saint Mary's, West Virginia
    38
    7
    Same problem with my 2004 took access panel off on pass side and bumped it started turning but not sounding good. I took mine off and took it apart to find the motor piled up with black brush dust and plenty of brush left. cleaned out the dust with air nozzle outside put it back in works ok for now. basscat has good info on replacement advance and autozone want $139. Good luck!
    68
    81,916
    Did the exact same thing on my daughters '04 SLS a few months ago with the same results. It's been flawless ever since.
  8. Remove Advertisements
