4.5 Liter to 4.9 Liter Engine Swap
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 4.5 Liter to 4.9 Liter Engine Swap in Past Cadillac Vehicle Discussion; Hi There! I have a question and was wondering if anyone knew if you can swap a complete 4.5 Liter ...
    caddyman93 is offline Cadillac Owners Member
    Oct 2003
    Toronto, Canada
    11
    Hi There! I have a question and was wondering if anyone knew if you can swap a complete 4.5 Liter V8 in a 1988 Caddy Sedan Deville for a complete 4.9 Liter from a 91 to 93 Deville. The wrecker near my house says this is possible, and that he has done one before in an 87 Deville, he says the 4.9L directly bolt up and all you have to do is change part of the wiring harness and ECM to make it run as a Multi-Port fuel injected engine instead of throttle body. Just wondering of anyone else knew the particulars of being able to do this. Thanks, Mike.
    bitdcc is offline Cadillac Owners Member
    Apr 2004
    5
    Re: 4.5 Liter to 4.9 Liter Engine Swap
    Just a follow up... Did you ever do the swap and if so, what are the swap details for the multi-port f.i.???
    HippieD9 is offline Cadillac Owners Fanatic
    Nov 2003
    Suburb of Chicago
    34
    176
    You just can't do it that easily. I've swapped a 4.9 in for a 4.1 in a 87 deville, but kept the TBI injection. Converting to MPI is just way more work than you want to do! If i remember right, you reuse the intake and TB, and the old valve covers (JUST the covers, you want the 4.9 heads) and exhaust manifolds. Other than that it's pretty simple. Let me know if you need more info.
    Peace,
    D.
