Installing after market Stereo "JVC"
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Installing after market Stereo "JVC" in Past Cadillac Vehicle Discussion; I just ordered a JVC double din stereo that I plan on installing. I know there some sort of adapter ...
    deville905's Avatar
    deville905 is offline Cadillac Owners Member
    Automobile(s): 2005 Deville,1999 Eldorado
    Nov 2013
    Memphis,TN
    43
    I just ordered a JVC double din stereo that I plan on installing. I know there some sort of adapter I will need so no need of cutting wires for a perfect fit. How do you remove the rear seat so I can install 6*9 speakers in the rear?
    cdv93's Avatar
    cdv93 is offline Cadillac Owners Member
    Automobile(s): 1993 Coupe DeVille
    Nov 2013
    Destin, FL
    67
    13
    Re: Installing after market Stereo "JVC"
    The speakers in my '93 are accessed from the trunk. Are you sure yours are accessed by removing the seat? Mine have plastic hand-tighten nuts to hold covers surrounding the speakers. Take them off and the mounting hardware for the speakers can then be removed.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,845
    Quote Originally Posted by deville905 View Post
    do you have the BOSE stereo?
    do you have the 10" sub under the rear shelf?
    remove the bottom cushion - it just pulls up at the front - and out -
    be sure to unplug the wire connector - on the passenger side - for the rear seat heat -
    remove the seat belt/retainer bolts at the bottom of the seatback -
    there are 4 spring clips that hold the top of the seatback in place -
    to release these clips - use a long flat blade screwdriver -
    start at the outside edge -
    slip the screwdriver between the seat back and rear deck -
    you can pull the seatback forward a little -
    slide the screwdriver towards the center - a couple/few inches
    you will feel the first clip -
    GENTLY move the screwdriver around until the clip is released -
    the first clip is the most difficult -
    after the first one is released -
    you can pull the seatback forward to see the other clips easily -
    I would like to make a suggestion -
    with all the goofy things going on with your car already -
    hold off on the radio swap until all the other gremlins are worked out -
    radio swaps are a PRIME SOURCE of additional problems in Cadillacs -
    it's just a thought -
