Results 1 to 3 of 3
Thread: 2002 DTS transmission problems
    AKALEFTY is offline Cadillac Owners Member
    Automobile(s): 2002 deville dts
    May 2013
    Seattle
    30
    164k on original trans in traffic notice at 5 mph it jolts like it slipped then catches does this mean my trans is close to death? Also i know my torque converter is bad that little piece of rubber how long do i wait to fix these problems? What would be the way to go here rebuilt or get a new trans? What's the cost difference? Anyones input would gladly help thanks.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: 2002 DTS transmission problems
    Check fluid level? Mounts?
    How do you know your torque converter is bad?
    What is that little piece of rubber?
    May 2013
    Seattle
    30
    I know torque converter is bad by the code. Left it alone because i'm not taking long road trips anymore & the shop said it was some little rubber piece that cost 50 cent. Emission test throughs the code evry year now. Since the torq is in the trans figure i wait till trans gave up. Took care of front mount just this summer. Low oil could be but why only at 5mph? What's that between 1st & 2nd gear shift & not between the other gears?
  • You may not post replies
