A bit of a head scratcher re tire rotation...
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, A bit of a head scratcher re tire rotation... in Past Cadillac Vehicle Discussion; The question came to mind about tire rotation and the pressure monitoring system. I'm not familiar with some of the ...
    knotgoalie's Avatar
    knotgoalie is offline Cadillac Owners Fanatic
    Automobile(s): 04 DHS
    Oct 2013
    Ontario, Canada
    61
    279
    The question came to mind about tire rotation and the pressure monitoring system. I'm not familiar with some of the criteria of the monitor and as such I ask, will the monitor still show accurately which tire is being read on its display after rotation? The system should still read the pressures but will it "know" what wheel it is actually reading? Would the data be specific to the transponder at the wheel or the receiver in the car?
    Or, am I just worrying about a "what if" that isn't an issue?
    J.R.
    Sep 2003
    Metro ATL
    4,854
    Re: A bit of a head scratcher re tire rotation...
    Quote Originally Posted by knotgoalie View Post
    ....will the monitor still show accurately which tire is being read on its display after rotation?
    Yes. The 'gotcha' is the tires/wheels will be in different locations after the rotation therefore the display for the LF tire/wheel will indicate the pressure in the tire that "used to be" in the LF position.
    The pressure data is specific to the sensor/transmitter in each wheel.
    Following a rotation it is necessary to have the receiver relearn the vehicle position of the four transmitters. Easy enough on your car.
    Use a large magnet. If this procedure fails, try a magnet with greater flux density.
    1) Ignition ON.
    2) Press LOCK + UN-LOCK key fob buttons simultaneously until the horn chirps.
    3) Starting with LF wheel, hold the magnet in contact with the valve stem
    until the horn chirps. Then RF, then RR, then LR. After LR, the horn
    will chirp twice to indicate the relearn was successful.
    There is a timer running that allows 1 minute between wheels and
    5 minutes total elapsed time.
    69
    82,155
    AND, if it doesn't work, you may have to wait for warmer weather. Mine don't seem to take the recalibration in cold weather.
    knotgoalie's Avatar
    Oct 2013
    Ontario, Canada
    61
    279
    Jim, thanks very much for bringing me up to speed on how the system functions and for the great walk through of the recalibration process...it did have me wondering. I just might print those instructions in a business card size, laminate it and it can live in the glovebox
    J.R.
    knotgoalie's Avatar
    Oct 2013
    Ontario, Canada
    61
    279
    Thanks for that Ranger..."If at first you don't succeed, try again in the spring"
    J.R.
  8. Remove Advertisements
