How to tell if I have " electronic adjustable suspension " ?
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, How to tell if I have " electronic adjustable suspension " ? in Past Cadillac Vehicle Discussion; After getting the wheels spin balanced, the guy mentioned to me the rear shock was leaking fairly bad. I had ...
    JimInMich is offline Cadillac Owners Member
    Automobile(s): 2001 DHS 67,000 miles
    Dec 2013
    56
    41
    After getting the wheels spin balanced, the guy mentioned to me the rear shock was leaking fairly bad. I had noticed the rear end sway abnormally after running over some potholes, so I wouldn't doubt it.
    While looking online to buy a pair of shocks, I noticed this disclaimer:
    "Except electronic adjustable suspension"
    How do I tell if I have this feature? Just bought the car ( 2001 Deville DHS ), so I don't know much about it.
    markmnj's Avatar
    markmnj is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Cadillac Hearse, 2002 Cadillac DHS
    Oct 2013
    Hampton Township, NJ
    269
    Re: How to tell if I have " electronic adjustable suspension " ?
    If you have a DHS you most likely do not have electronic suspension. DTS models came with it. To be 110% certain, check your car's RPO code sticker. You can find it inside the trunk on the inside of the spare tire cover. The suspension code will begin with "FE" followed by a number. Take that and compare it to this site posted by another member: http://aplsweb.com/Topics/TopicPix/RPO.pdf
    FYI: "FE1" indicates non electronic suspension. See circled area on attached photo. I just replaced my factory air shocks with a set of Monroe MA822's so this is fresh in my head. They were a direct replacement and accept factory air lines will connect without modification.
    Dec 2013
    56
    41
    Thank You! Just ordered a pair from Advance Auto for $57 including tax, pick up at store. Includes a $25 off next $50 purchase coupon, now I gotta buy something else...lol
    markmnj's Avatar
    Oct 2013
    269
    Not bad
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Are the $57 shocks "air" leveling or coil spring overloads? Seems awful cheap for new air shocks. $25 each?
    69
    82,399
    Monroe MA822's are direct replacements with the air assist. I just installed a set in mine and my wife's '05 LeSabre last summer. I believe I paid $52 & $55 respectively INCL shipping from http://www.autopartstomorrow.com/
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Quote Originally Posted by markmnj View Post
    incorrect -
    FE1 refers to the "soft ride" suspension -
    FE3 would be the RPO code for "firm" or "sport" suspension -
    it refers to the stiffness and size of springs and sway bars -
    has nothing to do with electronic - or passive -
    F45 is the RPO code for "electronic" struts and shocks -
    "CONTINUOUSLY VARIABLE REAL TIME DAMPING"
    or CVRSS - Continuously Variable Road Sensing Suspension"
    ALL FE3 equipped cars came with the F45 - electronic shocks/struts -
    there were cases of FE1 equipped Devilles also having the F45 option -
    I believe these were mostly for export -
    and - just for the record -
    F55 is the magnaride system -
    they all have the FE3 suspension -
    again - just for the record - F55 was never available on a Deville -
    I am simply clearing up various RPO codes -
    so - if you do not have either the F45 or F55 RPO codes -
    you have "passive" - or non-electronic struts and shocks -
    Quote Originally Posted by JimInMich View Post
    the Monroe MA822 is an EXCELLENT choice -
    and that is a terrific price -
    Quote Originally Posted by stoveguyy View Post
    YES -
    that's the VALUE you get from Monroe -
    GREAT shock - at a GREAT price -
  10. Remove Advertisements
