Sage advice when replacing power steering pump gaskets?
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Sage advice when replacing power steering pump gaskets? in Past Cadillac Vehicle Discussion; Is there anything special to keep in mind when replacing the seals and o-rings in a power steering pump? Thanks...
    scooter500's Avatar
    scooter500 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 DTS super traveller
    Oct 2013
    on the coast in Virginia
    56
    126
    scooter500's Avatar
    Oct 2013
    56
    126
    Re: Sage advice when replacing power steering pump gaskets?
    Anyone every replaced all their seals in the power streering before? If so was it smooth sailing?
    ***** After researching this I decided not to replace the seals although it looked pretty doable, but to instead buy a rebuilt pump with a couple better designed parts inside for only about $35, not counting the core charge. i also gained a couple tips while surfing online and will now flush the lines, replace the filter and use some Redline power steering synthetic fluid as well.
