Misfire - 1991 Deville
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Misfire - 1991 Deville in Past Cadillac Vehicle Discussion; 91 Deville cap rotor plugs wires 02 sensor cat less but still missing In park if I raise idle let ...
    DEVIL~le's Avatar
    DEVIL~le is offline Cadillac Owners Member
    Automobile(s): 1991 Deville
    Oct 2013
    97
    In park if I raise idle let off gas it pops sounds like a back fire
    69
    82,180
    Re: misfire
    Might check for a vacuum leak.
    DEVIL~le's Avatar
    Oct 2013
    97
    Had a full tune up done replaced 1 vacuum line that was iffy
    It lo rpms its slight mis
    But mid rpms its worse
    Floor it,it misses but feels like its
    Running out of gas
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,569
    Re: Misfire - 1991 Deville
    what brand cap/rotor/wires/plugs -
    look inside the distributor - at the base of it -
    observe the tiny wires of the pick-up coil -
    those wires constantly flex - make sure they are intact -
    did you set the BASE timing at 10* BTDC -
    69
    82,180
    Quote Originally Posted by DEVIL~le View Post
    Running out of gas
    Have you verified fuel pressure?
    DEVIL~le's Avatar
    Oct 2013
    97
    tested fuel pressure this is what I got
    Key on (not running) 0psi
    Running 38psi
    Key off (after running) hold at 40psi
    All gm trucks and cars I've had prime will key is on except this one
    Buddy of mine said some vehicles don't
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    All vehicles with fuel injection prime the system. Otherwise, every start wood be long and sputtery.
    DEVIL~le's Avatar
    Oct 2013
    97
    That's what I said to him lol
    69
    82,180
    No fuel pressure at key on? That's odd.
  12. Remove Advertisements
