Cadillac has 200,000 miles, i feel like i should replace certain parts
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By reppinshadyvill
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Cadillac has 200,000 miles, i feel like i should replace certain parts in Past Cadillac Vehicle Discussion; My 2002 Cadillac Deville has 200,000 miles on it. I am afraid there are certain things that will go out ...
    rockhoundrob1 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Deville and 2009 DTS
    Apr 2009
    156
    My 2002 Cadillac Deville has 200,000 miles on it. I am afraid there are certain things that will go out and it will be a hassle to fix when it is not working.
    The crankshaft sensor, EGR valve, and Bank 1 coils have failed and was replaced. I already replaced the Alternator (it didn't fail, but I replaced it when the radiator needed to be replaced).
    Now I think I should replace the Camshaft sensor, Starter, Bank 2 Coils, and the fuel pump. I would rather replace these when it convenient, than when they actually fail and the timing is bad.
    How many miles do these items usually last? I would think they can go bad anytime after 100,000 miles. And which ones would you replace first?
    Thanks
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,940
    Re: Cadillac has 200,000 miles, i feel like i should replace certain parts
    Another one off to FWD...
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Any electronic part of your car could fail today, 100K from now, 500K from now, or never. Mechanical parts, such as the starter, there's no set mileage or age. You could come up with $15,000 worth of work that needs to be done if you start naming things that "might" fail soon. There's really no answer to this question.
    Belts, pulleys, tensioners, hoses, plugs... Any of that been done in the last 100K?
    thenaaks is offline Cadillac Owners Member
    Automobile(s): 04 deville
    Jul 2011
    Middle Tennessee
    36
    72
    MC is right. Check the things he listed. Perhaps check suspension components as well. Brand new electronic parts are just as likely to fail as the ones on the car now. It's a gamble either way.
    68
    82,081
    The list of potential replacement parts is endless. It'll let you know when it's time to replace something just like it did in the first 200K. If it ain't broke, don't fix it.
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    As an avionics tech for the USAF I can attest to the fact that a "brand new" part is just as likely to fail as one that has been in service for years. Hopefully a part will give you some notice before it goes out on you. More than likely, you will repair it after it breaks.
    98eldo32v likes this.
    The Donald is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville delagance
    Apr 2012
    Colorado
    210
    If it aint broke fix it till it is !! Works for me every time
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    I would even suggest that a replacement electronic part is more likely to fail.
    Many aftermarket replacements are not the same quality as the original.
    cormorant is offline Cadillac Owners Member
    Automobile(s): '96 Sedan DeVille
    Oct 2013
    70
    21
    I used to frequent a salvage yard that advertised: "All our parts have been road tested--unlike that new one in a box"
    cdv93's Avatar
    cdv93 is offline Cadillac Owners Member
    Automobile(s): 1993 Coupe DeVille
    Nov 2013
    Destin, FL
    67
    13
    I think you have proably gotten the idea from all of the suggestions posted. Forget about replacing electronic components and focus on the mechanical items - they will all wear and eventually need replacement. Also, don't forget the liquid systems and misc items like vacuum lines, spark plug wires, fuel filters, fuel injectors, etc. You are asking the right questions and having your vehicle on a preventive maintenance schedule will eliminate most on the road catastrophies.
  13. Remove Advertisements
