1994 DeVille Will Not Steer and Grinding and Vibration
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1994 DeVille Will Not Steer and Grinding and Vibration in Past Cadillac Vehicle Discussion; My dad's 1994 with 4.9 110k miles. Stated that he cannot move the wheel at all and that it is ...
    smeltjr is offline Cadillac Owners Member
    Jan 2005
    26
    My dad's 1994 with 4.9 110k miles. Stated that he cannot move the wheel at all and that it is grinding and vibrating. Engine starts and runs. Says had neighbor check and has fluid........I am a state away and have not seen it yet. Any ideas off hand? Pump? Rack? Gear? Let me know.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Maybe the "grinding" he's hearing is the pump aerating the fluid? Did he check if the fluid had bubbles in it?
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Re: 1994 DeVille Will Not Steer and Grinding and Vibration
    I bet the pump is seizing up. Had it happen once on my 4 cyl integra. It was enough to kill the engine. On these 8 cyl beasts i'm sure it will lower the idle and give you the vibration he's talking about.
    Jan 2005
    26
    Thanks guys. He is not very car smart so I do not know if it is circulating. I am off next week and he has heat in his garage. For bout $100 think I will try the pump route. He says he is done with the car and wants to give it to me. If it works great he can just keep it. And if not...............I am not pulling racks etc. He can have it towed for trade in.
    68
    81,887
    Is the grinding at idle (P/S pump) or while trying to turn the wheel (steering column)?
    Jan 2005
    26
    Thanks for the replies so far guys. Ranger, he can't turn the wheel so its making noise at idle. He had a neighbor look at it running and he said the vibration was coming from the pump shaft. I ordered a pump anyways and should be here tomorrow or Saturday. It is a Delco reman and that looks like it may have been an oops based on reman failure rates. But I can only find oem new and it is almost $300. Even though this car is in real nice shape, garage kept, and he bought it new, it is probably not worth much. Si I cannot see dumpin tons of $$ into it.
    $70 for new pump and o-ring set. Did not come with a reservoir and I don't know how hard this is to separate. Will advise when done. At least he has a heated garage........high in the 20's around here next few days.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Or try used? Car is not new, as you point out. So why not try a used pump?
    Jan 2005
    26
    pump here. last question on this is if any kind of quick disconnect is needed for the lines????
    scooter500's Avatar
    scooter500 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 DTS super traveller
    Oct 2013
    on the coast in Virginia
    55
    126
    Took me a while to spot this in the manual, but yes disconnect the "return line from adapter using special tool J 36391" (quick disconnect tool).
  12. Remove Advertisements
