03 deville starting problems
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By loops
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 03 deville starting problems in Past Cadillac Vehicle Discussion; turn key and get clacking.....like a bad battery. Put new baterry in and still the same thing....put 2nd one in ...
    loops is offline Cadillac Owners Member
    Automobile(s): 03 deville
    Dec 2013
    6
    turn key and get clacking.....like a bad battery. Put new baterry in and still the same thing....put 2nd one in and works OK for 2-3 weeks.
    starter no clacking again......check all cables...they are good..(pos..neg....sand and clean ground strap under seat and under hood near fuse box).....still clacking....change out relay under hood( starter 2) still clacking......install reman stater!!!! still clacking, but now when I release key....still clacks for 3-4 seconds before stopping.
    Any ideas here guys????
    68
    81,922
    Re: 03 deville starting problems
    If it keeps clicking AFTER you release the key and bad ignition switch comes to mind.
    Dec 2013
    6
    I agree.....definatley the ign switch, but why the starter will not engage??????????
    68
    81,922
    Because the switch is not closing the circuit to the starter relay (assuming that is your problem). Keep in mind, I'm talking about the switch down the column, NOT the key tumbler.
    Dec 2013
    6
    Thanks for that info!!! Since I am a moderately good with the tool belt ( my son and I restored a 1973 Dodge Dart) , anything special about removing the switch.....or to be careful of a airbag???????Will replace today and keep you informed!!!!!!
    is there any way to short the cicuit to see if the starter will spin (or another issue elsewhere). I do believe the switch is bad because the clicking continues for 5 seconds after releasing the key. This is a new symptom since replacing the starter........or I was not aware of it, because I am not the daily driver.
    68
    81,922
    ALWAYS be careful of the airbag.
    The only way I know of to test the starter is the old way of crossing the solenoid contacts with a screwdriver, but you'd have to remove the intake manifold to do that.
    You're looking at part #23. A FSM would come in rather handy.
    http://www.gmpartsgiant.com/Page_Pro...044&SortKey=60
    Dec 2013
    6
    Thanks for the parts breakdown and the airbag warning. Due to time restraints and Christmas quickly approaching , the 03 deville left today, on vacation to come back revived and fresh! When I receive post cards or any phone updates from the sunbathing Caddy, I will pass on the info.
    Dec 2013
    6
    So here are the results............turns out the new starter from Advanced Auto that I installed was defective!!!!!!!! Mechanic installed new starter, and I drove away to get refund from Advanced for the bad starter. I made it about 4 miles from my house, stopped at a store for a pack of butts......car does the same thing.....clicking away! Call Triple A....tow car back to service center to a shocked mechanic!...........turns out the problem the whole time was A LOOSE CONNECTION ON THE BLOCK (GROUND STRAP). I had tightened and cleaned all connections except for this one because I could not get my chubby fingers into the area where the bolt was!!!Go figure. I have to commend Jim Byrd Auto Service (Raleigh,NC) for doing the right thing, so rare. For all of the people with starting problems.......check all connections first..........BEFORE INSTALLING A STARTER, HAVE IT CHECKED TO MAKE SURE IT IS GOOD!!!!!!!
    rodnok01's Avatar
    Feb 2012
    NC
    6,633
    I can't count how many bad "New" starters and ground problems are posted here on a weekly basis. These are extremely picky about the grounds.
    68
    81,922
    While it is not impossible, a bad "new" part is rare and that should be a big red flag to anyone (even when it seems to be the only and obvious reason, been there, done that).
    Dec 2013
    6
    Thank you........this forum is worth a MILLION!!!!!!!! Anyone with classic Dodge/Plymouth issues come visit us at forabodiesonly.com
    talismandave likes this.
  14. Remove Advertisements
