slight miss 4.9
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, slight miss 4.9 in Past Cadillac Vehicle Discussion; I have a problem with my 95 Deville 4.9. the problem it my car has a slight miss that gets ...
    BUBBA KEITH is offline Cadillac Owners Member
    Automobile(s): 95 DEVILLE
    Nov 2013
    45
    slight miss 4.9
    I have a problem with my 95 Deville 4.9. the problem it my car has a slight miss that gets stronger as the temp reaches operating range. any suggestions? thanks for all help
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    Re: slight miss 4.9
    start by checking for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Nov 2013
    45
    Re: slight miss 4.9
    I checked for codes no codes present.
    69
    82,266
    Re: slight miss 4.9
    How old are the plugs, wires, cap & rotor? A weak coil can't be ruled out either.
    MRneatfreak- is offline Cadillac Owners Fanatic
    Automobile(s): (1) 97 Devilles, (1) 94 Deville, (1) GMC Suburban
    May 2011
    North Dakota
    41
    248
    Yep all the above. Check those tiny wires inside the distributor for shorts or at least make sure the Plastic wire insulation hasn't rubbed off and is touching the surrounding metal structure. Don't manipulate them too much as you will make them brittle wires worse. Try cleaning the white corrosion off the contacts in the cap, with a brass brush. Heat=resistance.
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: slight miss 4.9
    I had a slight miss in my '95 Deville 4.9 about 4 years ago.A complete tune up fixed that.
    Nov 2013
    45
    Re: slight miss 4.9
    I replaced cap, rotor, wires plugs just over a month ago
    LoveMyLac is offline Cadillac Owners Member
    Automobile(s): 1999 DeVille D'Elegence (RIP) 2001 Cadillac DeVille DTS
    Oct 2013
    82
    Re: slight miss 4.9
    Did you use Ac Delco plugs?
    Nov 2013
    45
    Re: slight miss 4.9
    I'll try the coil.. may as well I have done everything else.
    Quote Originally Posted by LoveMyLac View Post
    yes I used AC platinum
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Typical 4.9 reply... check injectors.
  13. Remove Advertisements
