Instrument cluster swap for a 2004 Deville
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Instrument cluster swap for a 2004 Deville in Past Cadillac Vehicle Discussion; Hello! Is it possible to replace a digital instrument cluster in a 2004 Deville with a used analogue instrument cluster ...
    tibi500cid's Avatar
    tibi500cid is offline Cadillac Owners Fanatic
    Automobile(s): 1976 Cadillac Fleetwood Brougham and 1996 DeVille
    Dec 2005
    Budapest Hungary/European Unio
    44
    121
    Hello!
    Is it possible to replace a digital instrument cluster in a 2004 Deville with a used analogue instrument cluster out of a DHS?
    It looks a lot better, but is it technically possible? Just disconnect the old one and plug in the new one?
    Instead of this
    this:
    tibi500cid's Avatar
    Dec 2005
    44
    121
    Re: Instrument cluster swap for a 2004 Deville
    I forgot to ask: will the mileage stay the correct value?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,261
    Not sure - but the replacement must be programmed by a GM service shop - using the original mileage and the car's VIN - it's not a direct swap at all -
    ............ see later posts for different info ..............2004 must have changed.
    68
    82,076
    It is plug n play. Logan did it several years ago.
    See post #8-10
    http://caddyinfo.ipbhost.com/index.php?showtopic=8795
    Feb 2006
    56,261
    Good to know - Post 10 explains the glitch.
    tibi500cid's Avatar
    Dec 2005
    44
    121
    Great! Thanks!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,487
    Quote Originally Posted by tibi500cid View Post
    actually - the analog cluster was used on 2000 to 2005 Deville DHS and DTS models -
    along with 1998 to 2004 Seville SLS and STS models -
    there are a few problems with swapping clusters -
    the mileage IS stored within the cluster -
    so - what ever mileage is on the replacement cluster -
    that is what the mileage will display -
    the mileage CAN NOT be changed by the dealer - or a TECH2 scanner -
    it must be sent to a licensed specialty speedo shop to be changed -
    one solution is to find a cluster with similar mileage -
    MOST clusters available on ebay list the current mileage -
    another problem is that some of the features of the donor car
    include special warning messages that appear on the DIC -
    for example -
    if the donor car came with TPMS - Tire Pressure Monitor System -
    and your car does not have it - you will constantly get the warning -
    "SERVICE TIRE PRESSURE SYSTEM" every time you start the engine -
    and it must be turned off/cleared manually - each and every time - by hitting the INFO button -
    likewise - if the cluster comes from a DTS or STS with F45 "active suspension -
    you will constantly get ABS and suspension codes - that can't be cleared -
    though neither the ABS nor the Traction Control fault lights will be illuminated -
    some have said these "options" can be removed from the cluster by using a TECH2 -
    but the "service advisers" at the dealers insist it can't be done -
    I have not actually talked with a tech who knows how to use a TECH2 -
    so I don't know if it's possible or not -
    it is also possible that some fault codes will NOT be displayed -
    because some features you DO have - are not registered within the cluster -
    so - YES - an analog cluster IS PLUG-N-PLAY - it WILL work - for the most part -
    HOWEVER - there are some problems -
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,374
    A lot of ebay cluster resellers will do the programming for you. You give them an electronic statement declaring the correct mileage and they charge $50-$100 extra to set the odometer.
    I bought a used cluster for my 01 F150 and paid $75 to have the digital odometer configured to match the old one. Worked fine, but of course that's an entirely different vehicle.
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    Options can be added/removed with a tech 2 f4om the cluster. I have been through most of the modules on my car to update the firmware and add features. I also programed my name in to the DIC instead Driver 1.
  12. Remove Advertisements
