04 Deville, Vibration Under Braking
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 04 Deville, Vibration Under Braking in Past Cadillac Vehicle Discussion; Hey guys! I own an 04 Deville, had it since 05. It was originally a rental and got a great ...
    NCDaveD is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Mar 2010
    4
    Hey guys! I own an 04 Deville, had it since 05. It was originally a rental and got a great deal on it. It currently has 145,000 miles and has developed a bad vibration (at times) under braking. New tires, turned rotors with new brakes front and rear, no change. Tire wear is good and consistant over all tires. Shocks original with original air ride. All front end parts (tie rods, etc) original. Vibration severity inconsistant, but always present (when braking).
    Time for shocks? If so, what are your recommendations. I like the soft ride and would like to keep it.
    Any help would be much appreciated.
    Thanks!
    NCDaveD
    69
    82,402
    Re: 04 Deville, Vibration Under Braking
    Sure sounds like rotors. How long has it been since they were turned?
    Mar 2010
    4
    That was my thinking as well, but the fronts were turned 15 months ago and the rears were turned in February of this year. My brother in law is a professional mechanic with his own brake lathe, and I watched as he turned them in his garage. The only thing I can think of is to pull out my dial indicator and check the runout on the fronts, just to make sure.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Swap the rotors and pads.
    knotgoalie's Avatar
    knotgoalie is offline Cadillac Owners Fanatic
    Automobile(s): 04 DHS
    Oct 2013
    Ontario, Canada
    61
    279
    Quote Originally Posted by 98eldo32v View Post
    ...and as long as its apart, give the hubs a look too.
    J.R.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Forever West
    26
    5,775
    Tie rod ends?
    69
    82,402
    Is it vibrating or pulsing? Big difference. These cars do tend to pulse. I've gone through it several times. It's caused by uneven brake pad deposits on the rotors so the brakes seem to grab, release, grab, release etc, etc. Many people will mistakenly call it "warped" rotors which is incorrect because rotors are cast iron and don't warp, but I digress. Have them trued up and the problem will go away (if it is pulsing), OR you can do what I just did a week ago. Ride the brake for about 1/2 mile or so. I rode it hard enough that it would not shift out of 2nd gear. That heated the rotors and scrubbed them clean. She now stops smoothly. DO NOT stop afterwards. You want to keep driving long enough to give them a chance to cool down.
    purelux is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 deville
    May 2011
    509
    Yup ranger is right I tried this after my new rotors started acting up and much improvement. I did the 60-20 stop a couple times on desolate highway then cool down tho. Only because of the way lights/stops are around me other way wasn't practical.
  11. Remove Advertisements
