96 DeVille starting hard when cold.
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 DeVille starting hard when cold. in Past Cadillac Vehicle Discussion; Tested the fuel pressure today- 42 psi when the pump goes on, stays there when engine running. Goes to 50 ...
    CJ in Michigan is offline Cadillac Owners Member
    Automobile(s): 96 Sedan DeVille
    Apr 2013
    58
    14
    Tested the fuel pressure today- 42 psi when the pump goes on, stays there when engine running. Goes to 50 psi when I remove the vacuum line from the regulator, which dosen't leak. The battery is a bit down at about 11v but the charging system is working at 13-14v.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Hard to start as in cranks but doesn't start, or doesn't crank?
    Your battery is toast. A healthy, fully charged battery puts out ~12.6 volts. 12.0 volts is essentially dead.
    Apr 2013
    58
    14
    Re: 96 DeVille starting hard when cold.
    At least I won't have to pull the tank yet-it started right up today but it was almost 60f out.
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by MoistCabbage
    Apr 2013
    58
    14
    It cranks fine but dosen't start right away like it does in warm conditions. I had to jump it this past week when it sat for 2 days in 30f weather. Time for a new battery it looks like.
    68
    82,062
    Quote Originally Posted by CJ in Michigan View Post
    A BIT down is an understatement.
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    So what could it mean when a battery is at 11.6 but passes a load test just fine.
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    669
    Could mean the load tester is faulty
    68
    82,062
    Yeah, something is amiss. It is impossible to have 11.6v and pass a load test.
    13ir14314's Avatar
    Jan 2012
    Minnesota
    22
    443
    Hmm, I don't know what's up then. I got my battery 2 years ago and I don't think I've ever seen it go above 12v in the DIC. After seeing many of the battery threads and low voltage I had the battery tested twice and it passed. Last year it started the car just fine when it was -23. I'm just a little concerned about the voltage being that low and getting stranded somewhere.
  13. Remove Advertisements
