trouble installing monroe 90009 rear shocks 95 deville 4.9L
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, trouble installing monroe 90009 rear shocks 95 deville 4.9L in Past Cadillac Vehicle Discussion; Replacing original rear shocks with Monroe 90009s. Could not get the top 90009 bolt through the mounting hole without interference ...
    mikennedy2282 is offline Cadillac Owners Member
    Automobile(s): 1995 deville 4.9L
    Oct 2013
    5
    Replacing original rear shocks with Monroe 90009s. Could not get the top 90009 bolt through the mounting hole without interference from the bottom arm that the bottom of the shock bolts to. Looks like i will have to take the bottom arm loose near where the bottom of the 90009 connects to get the 1-2 inches extra I need. Has this been others experience. The old shock went right back in because I could compress it. Am I missing something easy??
    Oct 2013
    5
    Re: trouble installing monroe 90009 rear shocks 95 deville 4.9L
    Answering my own thread. Took the bottom control arm loose to get the 2 extra inches needed to get the Monroe 90009 in place. Noticed the bottom knuckle bushing was shot, so glad I took it apart. Lots of good info on this site about changing knuckle bushings on this site. I am going to go with the Dorman bushing that comes with the right size sleeve and use a ball joint press from Auto Zone. Will report results.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by mikennedy2282 View Post
    first I will say you are posting in the wrong forum -
    this the the engine how-to forum -
    you should be posting in the Deville forum -
    next I will say that the coil-over shocks are a HORRIBLE CHOICE -
    they will bake your car wide like a truck -
    and the ride height will never be right -
    you should have gone with manual-fill air shocks -
    assuming the automatic level control isn't working properly -
    and you don't want to spend the $$$ to fix it -
