Sensors - 1995 4.9 coolant temp
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Sensors - 1995 4.9 coolant temp in Past Cadillac Vehicle Discussion; I would like to know if anyone can tell me the location of all the temp sensors on a 95 ...
    BUBBA KEITH is offline Cadillac Owners Member
    Automobile(s): 95 DEVILLE
    Nov 2013
    44
    I would like to know if anyone can tell me the location of all the temp sensors on a 95 Deville with a 4.9. I broke a sensor near the number 8 spark plug, while changing my plugs. cant seem to find out what this two wire sensor is.. thanks for any help.
    69
    82,173
    Re: sensors
    #519 is the ECT sensor and #556 is the MAT sensor.
    http://www.gmpartsgiant.com/Page_Pro...026&SortKey=36
    #243 is the MAP sensor
    http://www.gmpartsgiant.com/Page_Pro...027&SortKey=33
    Nov 2013
    44
    Re: sensors
    thanks for your help
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: Sensors - 1995 4.9 coolant temp
    The sensor you've described isn't present in any of the above photos.
    The engine COOLANT temp sensor is located in the intake manifold - no where near your description. It is in direct contact with the coolant and supplies temp data to the PCM specifically for engine management.
    You are looking for the engine METAL temp switch. It's threaded into the cast iron head and it's sole purpose is to control the dashboard temp dummy light. This is the switch right next to the #8 plug.
    Nov 2013
    44
    thanks for the help and the pic.
    GOT_BASS is offline Cadillac Owners Member
    Automobile(s): 1995 SEDAN DEVILLE 4.9
    May 2014
    11
    can somebody kindly give me a part # for the metal temp switch or another name to look it up under lol broke mine and now cant figure out how to look up a new 1 lol thanx in advance... iv checked all over the forums and parts places but haven't had any luck thank u
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,566
    Quote Originally Posted by GOT_BASS View Post
    engine temp switch -
    ACDELCO 1551107 -
    AIRTEX / WELLS 1H8 -
    STANDARD MOTOR PRODUCTS TX3T -
    DELPHI TS10075 -
    FOUR SEASONS 36403 -
    GOT_BASS likes this.
    May 2014
    11
    thank u for a quick reply... unfortunately those are for the coolant temp sensors not the same I need this guy temp sensor switch.png
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,566
    in that case -
    here ya go -
    STANDARD MOTOR PRODUCTS TS200 -
    AIRTEX 1T1067
    AC Delco D1865B -
    GM 25037224 -
    May 2014
    11
    your the man basscat!!! thank u sir!!
  13. Remove Advertisements
