2004 Deville check coolant light
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 Deville check coolant light in Past Cadillac Vehicle Discussion; I am losing a little less than a gallon a week of coolant from both the right and left front ...
    BlackInjun is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Deville
    Jun 2013
    50
    58
    I am losing a little less than a gallon a week of coolant from both the right and left front of the car right under the radiator. Engine is not running hot. Am thinking about taking it in with the Carchex warranty. Pepboys, Goodyear, Sears, Midas. Any thoughts on what this might be or those shops.
    Also have had a consistent check gas cap light even after changing gas cap. The only code is P0455 Evaporative emission gross leak or no flow.
    69
    82,177
    Re: 2004 Cadillac Deville check coolant light
    The leak may be from one or both of the radiator side tanks. They are a composite and tend to crack and seep over time.
    Any shop can be good or bad. All depends on the knowledge and skill of the mechanics and how it is managed.
    Check all the vacuum lines on the EVAP system.
    Jun 2013
    50
    58
    Thanks Ranger, are side tasks a separate component from the main radiator and how involved/pricey is this
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Good luck finding a side tank separately anywhere. Not worth the extra work anyway. You need a new radiator.
    69
    82,177
    Even if you can find them, I don't think a whole new radiator is that much more.
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Change your radiator and save yourself tons of pain and agony.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,566
    Re: 2004 Deville check coolant light
    Quote Originally Posted by BlackInjun View Post
    the radiator I HIGHLY RECOMMEND - is the SPECTRA PREMIUM #CU2491 -
    assuming you do not have a DTS model with the Engine Oil Cooler -
    ebay has the best price - $101.95 - with free shipping -
    http://www.ebay.com/itm/SPECTRA-PREM...3217f9&vxp=mtr
    if - for some reason - you don't want to use ebay -
    amazon has this radiator for $131.75 - with free shipping -
    http://www.amazon.com/Spectra-Premiu.../dp/B000C7QHJY
    autozone wants over $180 for it -
    Jun 2013
    50
    58
    Thanks all, it was the outlet tank on the passenger side. Radiator hoses thermostat and gaskets 1198 at pepboys. They said 4 hours labor. Carchex warranty is paying 6 of it otherwise I'd be passed about the high price. Do you all think that pricing is fair
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,594
    Someone is paying top retail and max labor on that job. I'll bet that you could assemble all those parts plus coolant for less than $250. That puts the labor at $950 - $240 an hour.
    Go to a NAPA, price out the same parts, and faint. or......... get into www.gmpartsgiant.com and price the parts there.
    (The GM book labor for that job does come in at about 4 hours)
    Sep 2010
    East Boston MA.
    29
    26,325
    I would STRONGLY advise against having Pep Boys do the repair.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,566
    $1200 is RIDICULOUS -
    4 hours labor - OK - @100/hr - $400
    here is what you COULD ACTUALLY buy the parts for -
    RADIATOR-
    Spectra - $102 - ebay
    ACDelco - $215 - rockauto -
    WATER PUMP -
    Gates or Bosch - $29 - rockauto -
    ACDelco $62 - rockauto -
    RADIATOR HOSES -
    LOWER -
    Gates - $6.49 - rockauto -
    ACDelco - $8.57 - rockauto -
    UPPER -
    Gates - $14.07 - rockauto -
    ACDelco - $17.78 - rockauto -
    THERMOSTAT - which you DO NOT NEED -
    Stant - $10.05 - rockauto
    ACDelco - $21.79 - rockauto
    THERMOSTAT - WITH HOUSING -
    ACDelco - $53.79 - rockauto -
    new coolant - $20 -
    new coolant - $30 -
    TOTAL you could actually buy the parts for $181.61
    $400 - labor @100/hr
    $182 - parts
    $582 - TOTAL
    even using ALL the expensive ACDelco parts -
    WHICH I GUARANTEE THEY DIDN'T USE -
    total parts cost would still only be
    $387.14 -
    $400.00 labor
    $787.14 TOTAL -
    69
    82,177
    $1198? Yikes! Stick 'em up hombre.
    Jun 2013
    50
    58
    Alright here's the final
    Spectra 262
    Coolant exchange 57
    Proline orange 14
    R&D radiator 364
    Lower radiator hose 19
    Thermostat gasket 6
    Thermostat stant 30
    R&D the most at 130
    Total 930
    Carchex paid 523
    I knew they got over as soon as I saw a reply earlier problem was I had already said go but u all still saved me 170
    Lesson learned
    Post read then say go not post say go then read
  16. #14
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    383
    i wouldnt let pep boys change the air freshener hanging from my mirror
  17. #15
    Jun 2013
    50
    58
    You know what after looking today i have green antifreeze as opposed to the orange dexcool now my receipt says proline orange f/s a/f. Does it make much difference or even a little difference so that i should go back and be indignant
  18. Remove Advertisements
