01 Deville A/C plenum removal
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 01 Deville A/C plenum removal in Past Cadillac Vehicle Discussion; I have a 01 Deville base. I was wondering If it Is possible to remove and clean the a/c and ...
    mikeymorehead is offline Cadillac Owners Member
    Automobile(s): 2001 Deville Base
    Dec 2004
    NE Texas
    45
    20
    I have a 01 Deville base. I was wondering If it Is possible to remove and clean the a/c and heater plenum, just to clean not to change heater core, without removing dash? I thought I had a leaking heater core but now I'm not so sure. When I got the car the condensate drain hose was clogged and when I was clearing it, it came out of the hole because it was deteriorated. There seemed to be a lot of sludge in the plenum and it continues to get water in both passenger and driver floor. I know I need to replace the drain tube but would it missing cause the water in the floor?
    68
    81,920
    Re: 01 Deville A/C plenum removal
    Plenum? Are you talking about the HVAC housing on the firewall or the duct work in the cabin?
    Dec 2004
    NE Texas
    45
    20
    The housing in the cabin that encases the heater core and evap coil. I figured if the bottom could be removed, without removing the dash so I can clean it, I would do that, otherwise if the dash does have to come out I might as well go ahead and replace the heater core while I'm at it.
    68
    81,920
    Not sure just what has to be removed to do that without a FSM (which would not be a bad idea to have on hand), but I suspect it will be a bit involved.
    Maybe this will help some.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Looks almost identical to the setup in the Seville. Dash has to come out.
    Not the simplest job. And the heater core requires even more disassembly.
    Dec 2004
    NE Texas
    45
    20
    That's kinda what I figured. I appreciate your help. What about the condensate drain hose? Would it being gone cause water in the floor? I have one ordered should be in Monday.
    68
    81,920
    I would think it would still drain with the hose missing. There should simply be a big drain hole without it.
    Dec 2004
    NE Texas
    45
    20
    Thanks a lot guys. Looks like I have a long weekend of work ahead. Hey, Thanksgiving is coming up!
    Dec 2004
    NE Texas
    45
    20
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by mikeymorehead View Post
    do you have a sunroof?
    Dec 2004
    NE Texas
    45
    20
    Yes I do. And for whatever reason I never thought of that. I'll check those drain hoses. But if they were clogged wouldn't the roof be wet?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    not necessarily - but typically - the floor DOES get wet -
    there are 4 drains - I suspect the 2 front drains are plugged -
    the best method of clearing the hoses is to use weed-wacker line -
    and feed it down the hoses -
    if you use compressed air - BE VERY CAREFUL -
    if you blow the hoses off the sunroof frame - you REALLY have problems -
    my clue was that if the AC evap drain gets plugged -
    the passenger side floor gets wet - NOT the drivers side -
    Dec 2004
    NE Texas
    45
    20
    I was thinking the same thing but there was water on the bottom of the plenum on the drivers side, but it wasn't hot just kinda "room temperature".
  16. #14
    68
    81,920
    I'd pull the A pillar covers and have a look see. That is a LOT easier. MC's pictures look down right scary.
  17. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    The tubes are either black or opaque (or a mix for some reason), you won't really be able to see water in them. The clog would be at the "pinched" grommets anyway. Weed wackier line, or actually inspecting the grommets is the way to check for/ clear a clog. The ends of the grommets should really be cut off anyway.
  18. Remove Advertisements
