No crank issue
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 46
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, No crank issue in Past Cadillac Vehicle Discussion; I have a 2003 Deville and just recently my battery went dead. Jumped it and no crank. I have checked ...
    wdavidson09 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville
    Nov 2013
    25
    22
    No crank issue
    I have a 2003 Deville and just recently my battery went dead. Jumped it and no crank. I have checked every fuse in the thing and all is well. Crossed starter relay and it cranks perfect. Crossed the terminals on the battery and still nothing. What i find weird is that on my gear indicator is that there are no boxes on the selected gear. Tried to get codes and have power at the dlc but when trying to check for codes it shows that there is no connection.
    Any ideas?
    68
    82,068
    Re: No crank issue
    Have you tried wiggling the gear shift while trying to start it?
    Nov 2013
    25
    22
    Re: No crank issue
    yup tried that for a bit. also tried to start in neutral
    68
    82,068
    Re: No crank issue
    Maybe a failed ignition switch?
    Nov 2013
    25
    22
    Re: No crank issue
    but would that cause it to not show any indicator for any gear? and also why it died?
    68
    82,068
    Re: No crank issue
    No, I don't think that has anything to do with the indicator. That I believe is controlled by the neutral safety switch. It could also cause a no start. That's why I asked if you wiggled the gear shift, but maybe the switch simply flat out failed. That should set a DTC though. You said there where no codes?
    Nov 2013
    25
    22
    Re: No crank issue
    i cant even connect to the car. it powers up my scanner but wont connect
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No need for a scan tool. See the "sticky" thread at the top of the FWD Deville/Fleetwood page on how to pull DTCs.
    Nov 2013
    25
    22
    Re: No crank issue
    Got home and tried to get the codes. Went to the PCM prompt and all it said was "no pcm data" or something along those lines. Maybe a PCM fault?
    68
    82,068
    Re: No crank issue
    No PCM "data" or no PCM codes?
    Nov 2013
    25
    22
    Re: No crank issue
    No PCM data.
    68
    82,068
    Re: No crank issue
    You want "PCM CODES?". Answer yes to THAT prompt.
    Nov 2013
    25
    22
    Re: No crank issue
    I did and it takes a second then just displays no PCM data.
  16. #14
    68
    82,068
    Re: No crank issue
    Hmm, I wonder if maybe you have a bad PCM, connection or ground.
    Back in post #1 you said "Crossed the terminals on the battery". What exactly did you mean by that?
  17. #15
    Nov 2013
    25
    22
    Re: No crank issue
    Removed both of the battery terminals and crossed them.
  18. Remove Advertisements
